Old 03-19-2015, 08:57 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
I wouldn't think a bent flex-plate would make that noise. You could setup a dial indicator down there on/against the flexplate to check.
IF it was the flexplate I would think it would be either cracked or the ring gear is separating at a point or two?
All I could think of...
