Old 04-18-2015, 09:55 PM
Sonar Chief's Avatar
Originally Posted by snappytravis View Post
Line the front edge of the door up with the front edge of rocker. See what that does to the qtr gap. I also see you have your car on a body cart. I think it would be best to have it sitting on suspension if at all possible. If you line up the front edge, Then see if the bottom gap is even along the bottom of door and rocker edge. Use the passengers side for reference if you haven't messed with those gaps yet. Just a few ideas..
Those were old pixs with the skins replaced to see how the door fit against the GM quarter ...and the car is now sitting on its suspension, trying to get things lined up and gap the door-quarter panel.
I did both door skins at the same time, so no reference there, the quarter panel is still on the pass side but the AMD skins are not the same as the GM ... grrrrrr!
I'll line up the front on the rocker and see if that helps. Do the professional shops gap everything W/O weatherstripping? And then just squish it when the door is closed?
Thanks for commenting .... any other ideas or pictures of 67 gaps?
Michael
Old 04-19-2015, 05:54 AM
Michael
Welcome back Michael
Old 04-20-2015, 08:46 AM
Question
Speaking of door gaps, Kevin... could you reference my third pix above and get a measurement from you r car? Hopefully you haven't taken them off for anything .... have you tried to put new weatherstripping on the old doors yet?
My doors seemed to close way to hard on the new weatherstripping ... as if, the gaps were TOO close!
Thanks Kevin ...
Old 04-20-2015, 09:14 AM
cwylie cwylie is offline
What should the gap at the bottom of the door to the rocker be?
Old 04-20-2015, 11:05 AM
I go by the body lines and top of the door then fill/adjust the bottom gap last. 1/4" without paint.
Old 04-20-2015, 05:42 PM
Question
That is what I have done so far, the AMD door skin fits better to the OEM quarter than it does the AMD quarter, grrrrrr. What concerns me is the distance from the front to back, ie... where to position the door so its not too close to the back but still closes with the striker in place, and ... the door still closes w new weatherstripping.
Old 04-20-2015, 08:08 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Michael
I think someone else posted to line the doors up without the strikers. That is how I do it, The weatherstrip always seem to be tight when a guy replaces them. I like to line the doors up without the weatherstrip in. I used amd qtrs, and skins on my 69 I had to cut the qtr at the top. Just like your picture and angle it back a little to open the top of the gap. I also had to weld a few spots on the edges of the doors then go back and file or grind them to make the gaps somewhat even and what I thought was good. I worked at a Toyota dealership for 10 years and this car drove me nuts for fit.. I don't see a lot of cars that people spend the extra time to get stuff to fit nicely. Pretty much rule of thumb would be to get bottom and rear gap good. Then install fender and pray it lines up good. If not start welding the edge.
