Old 05-09-2015, 06:48 AM
Ah never mind -- -- I scrolled back and saw and read the posts. Should have done that before my other post. But on the other hand - it (the post) bump TTT (refreshes) the "don't go there!!".
Old 05-09-2015, 07:27 AM
grendel grendel is offline
Sorry, I missed this while typing my wall of text.
Back to the build:
Anyone know how much the TA quarters bubble out?
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 05-09-2015, 10:05 AM
Back to the build:
i'll get you a picture after lunch. not only does it bulge out it has a nice roll at the top to blend in with the camaro quarter.
Old 05-09-2015, 10:18 AM
and I can probably use factory flares to get better tire coverage.
I have to admit, I like this:
68 GMC C1500
73 Camaro
Old 05-09-2015, 04:36 PM
Back to the build:
The quarter lip is actually the same as far as distance from the peak, the opening is also higher. But the bulge above the wheel arch is bigger.
Old 05-09-2015, 06:39 PM
Sounds like not a lot of gain, if I understand you correctly?
Edit to add: Maybe some measurements I could compare to mine, please?
68 GMC C1500
73 Camaro
Old 05-09-2015, 06:45 PM
It can be depending on how you go about it. You can add up to 2" of extra room with placement.
Old 05-09-2015, 06:57 PM
I edited my post, Vince. Can you pull some measurements on the 2" from some common point, like the body crease?
68 GMC C1500
73 Camaro
Old 05-09-2015, 10:39 PM
sorry, I got super busy after lunch and no way im going in tomorrow. my wife at me
I have a FB partial quarter, i'll mock it up to give you an idea.
Vince
Old 05-14-2015, 07:06 AM
bsharpe bsharpe is offline
My Firebird/ Trans am is 74" wide from the outside of the flares in the center of the wheel opening. I have stock dented quarter panels but I stretched the flares 1" on each side.
I posted pictures on my build thread.https://lateral-g.net/forums/show...t=48439&page=2
You could easily do something similar and modify the trans am flares to fit the Camaro if that is the look you want.
