Old 05-30-2015, 06:04 PM
andrewb70's Avatar
I wonder why those factory connectors fail. Hard to imagine that it is simply current draw. The Corvette fan is said to be 400watts, so it should draw less than 35 amps. Heat? Moisture? Other causes of failure?
As I posted, I plan to use the Delphi GT480 series connector, which is rated at 42 amps. Where did you source the 3 cavity Anderson connectors and terminals?
Andrew
Old 05-30-2015, 07:00 PM
erick_e erick_e is offline
Andrew
In most, but not all, of the failures I've seen the fans have been set to run at 100% by a custom tune instead of the factory 90%.
Got my parts from Mouser. Detailed parts list is in my corvette forum thread. Total cost was less than $35 for the connectors and terminals.
Old 05-31-2015, 09:14 AM
andrewb70's Avatar
I was under the impression that the fan controller won't even work with duty cycle numbers that are less than 5 and more than 90%. That was certainly the case when I was playing around with number on the Dominator ECU.
http://forums.holley.com/showthread....ling-Fan/page2
Andrew
Old 06-29-2015, 12:32 PM
Andrew
This info is what SPAL technical support gave me for their brushless fans.
Is there a % vs. VSS table? What's the thermostat temp on the Corvette?
Andrew
I haven't seen one either.
Old 06-29-2015, 12:33 PM
I just got my 17" brushless fan and I am going to try to figure out how to have my factory ECM control it. Since these brushless fans are supposed to be factory on the 2014+ Corvette, I was able to compare the 2014 tune for brushless fan against the pre 2014 fans that have a separate PWM controller as seen in this thread.
In HPTuners the 2014 fan is listed as a PWM EV fan operating at 100Hz where the pre 2014 fans are PWM electric operating at 128Hz.
I'm thinking that I can just change the fan type and frequency in my tune and it should work.
Any thoughts?
Old 07-05-2015, 07:00 AM
andrewb70's Avatar
Any thoughts?
I think that should work!
Andrew
Old 07-05-2015, 12:53 PM
andrewb70's Avatar
I have a little update. I've been driving the Cougar quite a bit and working on the tune, so I decided to play with the fan settings a bit. I had the fan set to 40% in the 190 and 200 degree cells, but I wanted to see how low I could go with the fan speed at idle and still maintain temps in the 193-195 range. So I lowered fan speed to 25% in the 190 and 200 degree cells and let the car idle for 5 minutes. No change in temps. This fan just kicks ass...
I also scaled the temps above 40 mph so that the fan doesn't kick on at all until 200 degrees. I think for me, having a hole in the hood helps a lot...LOL
My ultimate goal is to cycle that fan as little as needed...
Andrew
Old 07-12-2015, 06:44 AM
Andrew
Well, I finally got around to testing my theory about the brushless fans working with the factory ECM.
Bottom line, the factory ECU can control these fans. Since I had already replaced by previously burnt up fan connector I was able to quickly connect the brushless fan to my car with another connector. Its just as simple as connecting the B+, B-, and PWN wires together. The factory ECM commands 128Hz, and the brushless fan is recommended for 100Hz. SPAL tech support says 128 should be OK, but 100Hz would be optimal. This can easily be changed with HPTuners or EFI Live. Changing the PWM type was not required. PWM Electric is what is required, not PWM EV like the C7 Corvette.
Once connected I fired up the Tech2 and commanded the fan on. Below you see it running at 90% duty cycle. I had the fan facing down to create restricted airflow (to simulate radiator, condenser and
heat exchanger). Notice it only dropped .3v at 90%. Not bad considering the vehicle wasn't even running.
I didn't have time to test fit Dewitt's fan shroud with my EForce. Hopefully it fits, it's a beautiful shroud. But if it doesn't fit I might be able to make the brushless fan work with the original shroud with an adapter. The fan blade is the same dimension as the OEM blade, but the motor is a little smaller in diameter. I'll cross that bridge when I have to, if I have to. Hopefully the Dewitt's shroud doesn't interfere with my coolant lines and I don't have to.
Old 05-31-2015, 04:39 PM
mikels mikels is offline
Correct. Factory PWM controllers have max output @ 90% commanded duty cycle. I've never set them above to 'investigate potential failure modes', but could see that unknowledgeable calibrators could mistakenly assume 100%>90% so must be better.
Factory fans are rated in watts, stock C6 fan is a 400W (so @ 12.5 volts = 32 amps).
Newer 850W fans we've been using on higher output applications are ~68 amps (850/12.5). They use the connector that was shown a couple posts back. That and 10mm wire (between 6 and 8 ga). Have to consider generator output capability with all the high electrical loads.
Another benefit of PWM fans is they never have onrush of current draw since they ramp-up to output. Discrete fans can have considerable spike in amperage when turning on. (hard on electrical, idle stability, etc.)
Dave
Old 05-31-2015, 10:26 PM
CarlC CarlC is offline
Originally Posted by mikels View Post
Another benefit of PWM fans is they never have onrush of current draw since they ramp-up to output. Discrete fans can have considerable spike in amperage when turning on. (hard on electrical, idle stability, etc.)Dave
100% agree. Even with a 75A rating, the relay failed on the Camaro when using a Mark-VIII fan. The electrical connector at the fan also started to melt. PWM cured those problems. I won't ever do a discrete system again.
http:www.vaporworx.com
