Old 05-30-2015, 04:57 PM
erick_e erick_e is offline
After finally experiencing the melted connector on my corvette, I decided to upgrade to a more reliable solution that won't derate with high under hood temperatures.
I ended up going with a Anderson Power connector rated at 75A.
If you are interested you can read my post at the link below.
http://www.corvetteforum.com/forums/...connector.html
Old 05-30-2015, 07:04 PM
andrewb70's Avatar
I wonder why those factory connectors fail. Hard to imagine that it is simply current draw. The Corvette fan is said to be 400watts, so it should draw less than 35 amps. Heat? Moisture? Other causes of failure?
As I posted, I plan to use the Delphi GT480 series connector, which is rated at 42 amps. Where did you source the 3 cavity Anderson connectors and terminals?
Andrew
Old 05-30-2015, 08:00 PM
Andrew
In most, but not all, of the failures I've seen the fans have been set to run at 100% by a custom tune instead of the factory 90%.
Got my parts from Mouser. Detailed parts list is in my corvette forum thread. Total cost was less than $35 for the connectors and terminals.
Old 05-31-2015, 10:14 AM
andrewb70's Avatar
I was under the impression that the fan controller won't even work with duty cycle numbers that are less than 5 and more than 90%. That was certainly the case when I was playing around with number on the Dominator ECU.
http://forums.holley.com/showthread....ling-Fan/page2
Andrew
Old 05-31-2015, 05:39 PM
mikels mikels is offline
Correct. Factory PWM controllers have max output @ 90% commanded duty cycle. I've never set them above to 'investigate potential failure modes', but could see that unknowledgeable calibrators could mistakenly assume 100%>90% so must be better.
Factory fans are rated in watts, stock C6 fan is a 400W (so @ 12.5 volts = 32 amps).
Newer 850W fans we've been using on higher output applications are ~68 amps (850/12.5). They use the connector that was shown a couple posts back. That and 10mm wire (between 6 and 8 ga). Have to consider generator output capability with all the high electrical loads.
Another benefit of PWM fans is they never have onrush of current draw since they ramp-up to output. Discrete fans can have considerable spike in amperage when turning on. (hard on electrical, idle stability, etc.)
Dave
Old 05-31-2015, 11:26 PM
CarlC CarlC is offline
Originally Posted by mikels View Post
Another benefit of PWM fans is they never have onrush of current draw since they ramp-up to output. Discrete fans can have considerable spike in amperage when turning on. (hard on electrical, idle stability, etc.)Dave
100% agree. Even with a 75A rating, the relay failed on the Camaro when using a Mark-VIII fan. The electrical connector at the fan also started to melt. PWM cured those problems. I won't ever do a discrete system again.
http:www.vaporworx.com
Old 06-11-2015, 08:19 PM
130fe 130fe is offline
Post
Just saw this on FB, here is another option for integrating the GM AC pressure switch. https://www.facebook.com/pages/BP-Au...53192731414826 BP Automotive sell a dryer that has a metric port built in.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 06-15-2015, 02:00 PM
andrewb70's Avatar
Today I finished the mounting of my C6 fan to my radiator and I filled the coolant system. Started the engine and brought it up to temp. The fan gently started to run as the temps rose. It was beautiful.
Does anyone have an idea of what the ramp up table might look like?
Andrew
Old 06-15-2015, 02:36 PM
samckitt's Avatar
samckitt samckitt is offline
Stock 2013 Vette:
Scot
86 Monte SS
LS2/T56 Magnum
Old 06-15-2015, 03:00 PM
andrewb70's Avatar
Is there a % vs. VSS table? What's the thermostat temp on the Corvette?
Andrew
