Old 07-29-2015, 06:01 AM
JsTA JsTA is offline
Originally Posted by DavidBoren View Post
I really was hoping to not be confusing, and I apologize if I wasn't clear. The OP stated that a cam swap is in the plans, and I am under the impression that all 4.8/5.3 engines have vvt.
I would absolutely keep it. Hell, I would add it if it didn't.
Run an electric water pump and you don't have to worry about the vvt timing cover working with your front accessory drive.
Most 4.8 and 5.3 engines did not have VVT. That wasn't introduced until later in the Gen IV production run (2007ish or so I believe) so he won't have to worry about that if he got a 99-04 engine.
OP what year engine did you get?
Old 07-29-2015, 04:58 PM
Paraman1 Paraman1 is offline
Its an 02 out of a Tahoe . I picked up some 243 heads with the trunnion upgrade and springs that are good to .660 lift (I believe they are Texas Speed) .
Old 07-30-2015, 05:43 AM
Then you are good, that engine doesn't have VVT or AFM. Like others have said I would get those 243 heads decked and then make sure whatever cam you go with will not cause any piston to valve clearance issues (which you shouldn't because of the slightly dished pistons).
Old 07-30-2015, 06:48 AM
Paraman, as a point of reference, I built an early 5.3, 2001 if memory serves me well, that used mildly ported LS6/243 heads, LS6 intake, headers, and a small cam similar to what hifi utilized in his build. The car put 350hp and 350tq to the rear wheels through a 5 speed. The torque curve was ridiculously flat and broad. The engine sounded great at idle and drove even better. Point being, these are great engines that perform really well with simple modifications. You're on the right track. Don't over complicate this and you'll have a great engine on your hands. Good luck!
Old 10-17-2015, 08:14 PM
BowtieGent BowtieGent is offline
Out of curiosity, how much material are we talking about having removed, assuming these are virgin heads that haven't been decked previously?
