Old 07-30-2015, 06:43 AM
JsTA JsTA is offline
Originally Posted by Paraman1 View Post
Its an 02 out of a Tahoe . I picked up some 243 heads with the trunnion upgrade and springs that are good to .660 lift (I believe they are Texas Speed) .
Then you are good, that engine doesn't have VVT or AFM. Like others have said I would get those 243 heads decked and then make sure whatever cam you go with will not cause any piston to valve clearance issues (which you shouldn't because of the slightly dished pistons).
