Old 05-29-2015, 09:12 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
No fastback conversion on this one Rusty?
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 05-29-2015, 12:35 PM
GPR's Avatar
GPR GPR is offline
No he has all new interior and a Mustang to Fear one piece headliner for a coupe.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 05-29-2015, 09:10 PM
You guys are moving fast. It's amazing looking compared to what it started out as.
Old 06-07-2015, 10:54 AM
GPR's Avatar
GPR GPR is offline
The quarter panels, roof, rear deck panel and taillight panel lined up and welded in place
Rusty Gillis
Port Richey Fl
Old 06-15-2015, 08:06 AM
Justin@EntropyRad Justin@EntropyRad is offline
Default Right on
Gotta love fresh sheet metal
Old 06-26-2015, 03:53 PM
GPR's Avatar
GPR GPR is offline
The drip rails were removed and welded
Welds ground
We still have more work to do inside the car but to stop the surface Brian sanded it down to bare metal
I sprayed two coats of SPI black epoxy and it is back in the fab shop
Rusty Gillis
Port Richey Fl
Old 07-19-2015, 11:36 AM
GPR's Avatar
GPR GPR is offline
Brian is welding the rear floor and modifying the inner wheelhouse for more tire clearance.
Rear bulkhead panel welded in place
Welds ground and interior sanded and ready for SPI epoxy
Rusty Gillis
Port Richey Fl
Old 08-22-2015, 09:41 AM
GPR's Avatar
GPR GPR is offline
We had a major set back. Brian lined up the doors but when he went to line up the fenders and hood he found a major problem. A former employee welded the front end on wrong even though he measured and remeasured before welding. There was very little gap on the left door and a large gap on the right side so the front end had to be cut off. After working on this about two weeks at my expense Brian is satisfied with how it lines up and we should be able to start charging the customer again early next week.
The replacement outer torque box had to be modified to get it to fit.
Rusty Gillis
Port Richey Fl
Old 08-25-2015, 02:01 PM
GPR's Avatar
GPR GPR is offline
The repair is finished and a little epoxy was brushed on to stop the surface rust on the weld
Fitting the shock tower panels
Welding finished just need to start grinding
Rusty Gillis
Port Richey Fl
Old 09-02-2015, 03:18 PM
GPR's Avatar
GPR GPR is offline
After Brian finished the front end repair we sent if out to get the engine compartment and undercarriage sand blasted
Rusty Gillis
Port Richey Fl
