Old 07-06-2012, 03:44 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Originally Posted by ErikLS2 View Post
Current (amps) is the same throughout the entire circuit, meaning both the ground and positive cables need to be the same size (if they're the same length) for it to be right.
I am using #1 cables and the negative is bolted to trunk sheet metal. Is it OK to use 1/0 ground strap between the body and engine and another strap between engine to frame?
72 Camaro RS:SOLD
68 Camaro:
Old 07-06-2012, 11:04 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
With short run lengths like that on the ground side, you can run a much thinner cable than 1/0, like 4 or even 8 ga. It can be mathematically calculated but I can't tell you the formula off the top of my head. A thicker cable wont hurt you though except for the added weight. Do a voltage drop test on both the ground and positive cables with the engine cranking. To do that, measure with a volt meter from the positive battery terminal to the positive terminal on the starter. Then also from the negative terminal on the battery to the engine block. If you get a reading more than 0.1-0.2 volts, the wire is either too thin or the connections are dirty, have paint on them, etc. The idea is to have as thin a wire as you can without any voltage drop, with maybe 1 wire gauge thicker for comfort. Since the most current is flowing when the engine is cranking, that's when you want to do this test and the test will only work when current is actually flowing. Here's a handy little chart I found when Google-ing wire sizes too:
Erik
69 Camaro
Old 08-14-2015, 03:35 PM
jarhead's Avatar
jarhead jarhead is offline
good information
joe
Semper Fi
My 68 Torino
Old 10-20-2015, 09:02 AM
vstol vstol is offline
All good info and instead of starting a new thread I thought I would post my question. I am going to run the battery cable from the rear to a shut off switch on the dash then to the starter. First cable about 7 ft second about three. What gauge do you think I need to run, thanks
project below;
https://lateral-g.net/forums/showthread.php4?t=44704
Old 10-20-2015, 10:24 AM
72Z/28's Avatar
project below;
I used 1 gauge cable for the negative and positive terminals when I did the rewiring of the battery cables. The car had welding cables and changed to 1 gauge marine cables.
72 Camaro RS:SOLD
68 Camaro:
Old 10-20-2015, 10:53 AM
jarhead's Avatar
project below;
"VSTOL" Harrier pilot?
joe
Semper Fi
My 68 Torino
Old 10-20-2015, 04:20 PM
Semper Fi, 27 yrs on active duty flying A4M and Harriers, and you?
Old 10-21-2015, 10:29 AM
jarhead's Avatar
12/74 to 8/79
Multiple jobs,Supply,Accounting, allot of guard duty
Last duty station was MARMTD,4th LAAM Batallion, home of the HAWK missile
Semper Fi
joe
Semper Fi
My 68 Torino
Old 10-21-2015, 01:34 PM
Jay Hilliard's Avatar
Checkout QuickCar Racing Products. Their cable is very flexible.
Jay
Old 10-21-2015, 02:23 PM
Thanks I went to their site and they only go down to 2 gauge wire
The Following User Says Thank You to vstol For This Useful Post:
spatel2589 (12-11-2020)
