Old 10-03-2006, 10:42 AM
Speedster's Avatar
Speedster Speedster is offline
AAW is the way to go...
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 10-04-2006, 02:07 AM
Moabdude's Avatar
Moabdude Moabdude is offline
thanks guys,
but I have a simple Camaro with not a lot of electronics.
I have no:
- airco
- heater/blower (took it out to make a smooth firewall)
- electric fuel pump
- electric waterpump
- power windows
- power doorlocks
- RS headlight doors
I have:
- autometer gauges
- led taillights (on order)
- xenon headligths (on order)
- 1 wire alternator
do I really need the special Camaro kit?
do you think the generic 12 circuit kit will do fine?
what Painless or AAW kit do I have to Choose?
well thanks guys!!!!
Old 10-04-2006, 06:09 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Maybe you should just call the American Autowire sales number and have them explain your options to you and see what would work best for you.
My LS7 69 Camaro
Old 10-04-2006, 08:19 AM
fatlife's Avatar
fatlife fatlife is offline
Banned
I've installed 3 painless wiring kits and never had any problems. I've never used an AAW so I can't comment on theirs. One thing that painless has going for them and I'm not sure if AAW offers this, is that Painless makes a really killer fuse block, it mounts right where the old one went, has an integrated horn relay and uses the new Mini blade fuses.
Almost every other wire kit manufacturer uses a generic fuse block board that you have to unconvienantly mount somwhere under the dash, and then you have to fill in the stock hole in the firewall. This also means that you have to route all of your engine bay wires thourgh a hole/grommet in the firewall. So you can not disconnect the engine harness at the firewall anymore, which to me sucks. If AAW offers a bolt in fuse block then I see no reason not go with their systems.
I have had no problems with painless whatsoever, they have great tech people too.
Old 10-04-2006, 02:28 PM
mazspeed's Avatar
mazspeed mazspeed is offline
I have a Painless in my car, but have other AAW products. Let's put it this way, I should have had everything from AAW. I didn't know till it was too late. Also the customer service which is key, is one of the best things AAW does. They are so good that I consider Theresa from AAW a friend. That's how they make you feel. You cannot beat that.
Old 10-04-2006, 03:35 PM
fatlife's Avatar
Banned
so what was wrong with the painless?
Old 10-04-2006, 06:14 PM
Damn True's Avatar
Damn True Damn True is offline
Do the AAW kits have a provision for integration to LSx?
Old 10-05-2006, 03:32 AM
ProTouring442's Avatar
I had a problem with two of their generic 18 circut kits. A connector wasn't up to the job they were using it for. I don't know if they still use this connector or if it is in any of their other kits. Other than that, I had no problems.
Shiny Side Up!
Bill
'72 442 "Inamorata"
