Old 01-06-2016, 09:54 AM
markaaron80 markaaron80 is offline
id go 430hp and contact Brian Tooley and pick a cam from the Hot Rod mag issue. picked up over 80hp from the 480hp crate engine with just a cam swap. ended up with 575hp max but very tight piston to valve .003
http://www.superchevy.com/how-to/eng...ick-boomerang/
Old 01-06-2016, 09:44 PM
Tom.A's Avatar
Tom.A Tom.A is offline
I went with the 430HP LS3. Got the car running and then did a cam swap.
HP exceeds the 295/35/18 tires very easy. However the cam swap that I used does make car buck some what at low speeds but it is not a big issue and still does fine in traffic. It is 227/237 , 613/622 with 114 Lobe centers. Dyno numbers are very subjective but my car was 517HP / 497 TQ at the wheels through a 9" with 3.55 rear and a TKO600 with no other mods other than long tube headers. I feel it was a very generous day. Either way these LS engines are sneaky fast and start every time. They don't put out the same thump as a SBC can or BB does but way less drama on top of decent fuel mileage
Tom
Old 01-07-2016, 07:02 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
430 and a call to BT will get you 550 with good driveablity and you'll save a few bucks over the 525 if you do the swap yourself. Adding the cost of tuning may wipe out and savings.
Downside is you lose the warranty.
Old 01-08-2016, 11:00 PM
awr68's Avatar
awr68 awr68 is offline
All great info guys! I love real world experience! I'm wanting to change to a LS soon and this helps a lot!
Tony
'68 Camaro
Old 01-10-2016, 08:03 AM
MOREHORSEPOWER's Avatar
MOREHORSEPOWER MOREHORSEPOWER is offline
I would just buy the 525!
1 If I buy a new crate engine I would keep the WARRANTY !!
2 HP cost money ! I may be wrong but how to you gain 45 hp with just a cam swap alone in this engine ? If it started with the same platform as the 430 hp engine that is a gain of 95 hp .
3 When i was younger I was told a HP would cost $100 per HP . Today's money would more like $400 per HP.
Old 01-10-2016, 08:52 AM
Vega$69's Avatar
The 430 is a smog motor. To meet epa standards the exhaust side gets choked down among other things
Swap cams and badabing you get big power and great drivability.
Old 01-10-2016, 09:49 AM
randy randy is offline
i went with the 480hp version. Should fire up within 2 weeks. Might be next week. I wanted a little extra kick now and then in the future i will upgrade it. Nice learning curve and then tweaking everything else
Old 01-10-2016, 02:58 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
I went with the 525. Wouldn't change a thing.
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 01-17-2016, 08:37 AM
http://www.hotrod.com/features/1507-...ifolds-tested/
Old 01-18-2016, 08:16 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
I ended up with a GM crate 525HP.
_________
1965 Chevelle SS
Project Build
