Old 12-02-2015, 06:16 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Originally Posted by 1965_SS View Post
You still need to tune those GM crate motors even if you use the GM harness, right?
Video would be awesome!
I like a lopey idle...........I had a big block with a Comp Cam [email protected], that was pretty radical.
The GM Performance Harness in both the 480 and 525 are plug and play. No tuning was needed on either one.
Old 12-04-2015, 11:22 PM
gnx7's Avatar
gnx7 gnx7 is offline
Remember that HP is a measurement of torque over time.... so the LS7 would kick it in the nuts due to that alone (more torque). Add cam/headers to an LS7 and it will make 600hp+ with perfect driveability.
Old 12-05-2015, 06:29 AM
Vega$69's Avatar
The LS3 525 beats the stock LS7 across the board. Better HP and Torque
My 69 with the LS3/525 pulls my Corvette ZO6
Change the cam in the LS7 and 620-650 hp and 550 torque are easy #s to achieve and still very street friendly.
My last 69 I used an LS7 with a Texas Speed cam and ran 505 rear wheel at only 6200. Car was a beast. However my LS3/525 is also killer setup.
I just bought another LS7 for my kids build. Of course will do a cam change and convert to wet sump. Funny part is that just yesterday we started talking about selling the LS7 and buying a LS3/525. The money saved would pay for a lot of other stuff.
Old 01-06-2016, 09:54 AM
markaaron80 markaaron80 is offline
id go 430hp and contact Brian Tooley and pick a cam from the Hot Rod mag issue. picked up over 80hp from the 480hp crate engine with just a cam swap. ended up with 575hp max but very tight piston to valve .003
http://www.superchevy.com/how-to/eng...ick-boomerang/
Old 01-06-2016, 09:44 PM
Tom.A's Avatar
Tom.A Tom.A is offline
I went with the 430HP LS3. Got the car running and then did a cam swap.
HP exceeds the 295/35/18 tires very easy. However the cam swap that I used does make car buck some what at low speeds but it is not a big issue and still does fine in traffic. It is 227/237 , 613/622 with 114 Lobe centers. Dyno numbers are very subjective but my car was 517HP / 497 TQ at the wheels through a 9" with 3.55 rear and a TKO600 with no other mods other than long tube headers. I feel it was a very generous day. Either way these LS engines are sneaky fast and start every time. They don't put out the same thump as a SBC can or BB does but way less drama on top of decent fuel mileage
Tom
Old 01-07-2016, 07:02 AM
Vega$69's Avatar
430 and a call to BT will get you 550 with good driveablity and you'll save a few bucks over the 525 if you do the swap yourself. Adding the cost of tuning may wipe out and savings.
Downside is you lose the warranty.
Old 01-08-2016, 11:00 PM
awr68's Avatar
awr68 awr68 is offline
All great info guys! I love real world experience! I'm wanting to change to a LS soon and this helps a lot!
Tony
'68 Camaro
Old 01-10-2016, 08:03 AM
MOREHORSEPOWER's Avatar
MOREHORSEPOWER MOREHORSEPOWER is offline
I would just buy the 525!
1 If I buy a new crate engine I would keep the WARRANTY !!
2 HP cost money ! I may be wrong but how to you gain 45 hp with just a cam swap alone in this engine ? If it started with the same platform as the 430 hp engine that is a gain of 95 hp .
3 When i was younger I was told a HP would cost $100 per HP . Today's money would more like $400 per HP.
Old 01-10-2016, 08:52 AM
Vega$69's Avatar
The 430 is a smog motor. To meet epa standards the exhaust side gets choked down among other things
Swap cams and badabing you get big power and great drivability.
Old 01-10-2016, 09:49 AM
randy randy is offline
i went with the 480hp version. Should fire up within 2 weeks. Might be next week. I wanted a little extra kick now and then in the future i will upgrade it. Nice learning curve and then tweaking everything else
