Old 01-09-2016, 11:07 AM
slimjim's Avatar
slimjim slimjim is offline
Originally Posted by John510 View Post
Heres a 19x12 with 5.5 BS for reference
[URL=http://s527.photobucket.com/user/JohnS510/media/37B30C1E-50EB-496A-BDBD-50AB1BC3CE55-3556-000001E4340AA2C8.jpg.html]
John do you happen to know your measurements for the rear end? I'm using the same size wheel but with a 5.25" backspace
Old 01-10-2016, 08:09 PM
John510's Avatar
John510 John510 is offline
My rear is 54 3/4" Fab9
[SIGPIC][/SIGPIC]
Old 01-15-2016, 09:29 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Is that a WMS to WMS measurement?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-15-2016, 10:30 PM
Swain's Avatar
Swain Swain is offline
I have 18x12's with 5.625 back space. 54.75" axle flange to axle flange
68 camaro
714-345-3865 text for pics
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 01-16-2016, 07:42 PM
TheJDMan's Avatar
68 camaro
That 54.75" is from housing flange to housing flange not axle flange. The WMS to WMS of that rear end is in the neighborhood of 57" otherwise those wheels will not fit that car. My 18x12 5.6bs wheels are running on my 57" WMS to WMS rear end.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-16-2016, 09:13 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I'm just finishing up a 67 with 17x12" rear wheels, 6" BS. I had the 12 bolt narrowed to 55" WMS to WMS. Running a 315/35/17. The rear in my 69 is 56" WMS to WMS running 18x12, 6" BS and 335/30/18. Both cars have rolled fender lips. Each car is a bit different, but I have nearly equal space between the tire/fender lip, and tire/inner wheel house. Hope this doesnt muddy the water, just thought it may help for comparison. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-24-2016, 07:09 AM
Tony V Tony V is offline
just to make sure I understand WMS is the measurement from outer surface of the brake rotor (wheel mounting surface)??? correct?
Old 01-24-2016, 12:23 PM
Z06vette's Avatar
The measurements I listed are without the rotors, but yes, the outer axle flange that the wheel studs go through. I take the rotor thickness into account, but dont measure with them mounted.
69 RS LS3/T56
67 RS LS2/T56
Old 02-12-2016, 09:22 AM
Steve couple questions, what tire size are you running in the back and did you need to modify your front inner fender wheel wells? Understand you rolled the outer fender lip but i was more concerned with the inside clearance.
Thx
Tony
Old 01-16-2016, 02:58 PM
John510's Avatar
Not sure. Just reading off the receipt from when it was ordered. I believe it is the total width.
[SIGPIC][/SIGPIC]
