Old 03-03-2016, 10:31 PM
64mali's Avatar
64mali 64mali is offline
Thanks for the reply Josh. So when you say the kit is designed to lower the car 2", is that referring to the kit itself with the shock adjusted somewhere in the middle giving me room to go up or down a little more. I'm sure I will want to be lower than 2" and worried I might bottom out the shock. I'm just trying to figure out if I should order a shorter shock from the start or get the kit and check it on the car. I pretty much want it as low as possible while stuffing a 20" wheel in there.
Old 03-03-2016, 10:36 PM
64mali's Avatar
This is roughly the ride height I want to go. It'll have to be a little higher but as close to this as I can get
Old 03-03-2016, 11:58 PM
check out Banko's 64. Ridetech kit with 19's
https://lateral-g.net/forums/showthread.php4?t=46536
Old 03-07-2016, 10:22 AM
64mali's Avatar
Banko's 65 is sick. I love the ride height and stance. It sounded like he did some notch work in the rear. Is that car still around?
Old 03-23-2016, 05:19 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
I just now saw your reply, sorry for the late response!
You're correct, the 2" drop is with the shock right at the mid-travel mark. We want you to have the lowered height but still have enough extension/compression so you don't have to worry about topping or bottoming out. Typically, we don't recommend going with a shorter shock if you don't have to, it could hinder the ride quality in some bad ways! Vince posted a pretty good example above
Old 03-25-2016, 10:16 PM
64mali's Avatar
Thank you guys for the advice. I ended up ordering the kit and I'm hopeful it will be where I want it. I'll update when I get it in. I can't wait.
Old 03-31-2016, 05:18 AM
Let me know if you need anything!
