Closed Thread
Old 03-03-2016, 07:26 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Default New 13" Wilwood 6 piston C6 Brakes
Item Location (City/State):Kenna,WV
Price:$1,200 plus $75 shipping in Cont. U.S.
Description:I have a brand new set of Wilwood front brakes for DSE subframes or any C6 spindles,they were only bolted on my project and never had fluid in or hoses connected to them.I am only selling to go to 14" because of my larger open wheels.
Old 03-03-2016, 08:53 AM
NvrDun71 NvrDun71 is offline
Is there a wilwood part number associated with this kit?
71' Nova - LY6, T56
Old 03-03-2016, 08:57 AM
tubbed69's Avatar
http://www.ebay.com/itm/WILWOOD-DISC...GMV-Gg&vxp=mtr
Old 03-03-2016, 09:46 AM
Mickav6 Mickav6 is offline
Can you ship In canada ?
Old 03-03-2016, 09:53 AM
tubbed69's Avatar
I will check later today,what part of Canada?
Old 03-08-2016, 09:02 AM
tubbed69's Avatar
Bump,need to sell,make reasonable offer
Old 03-11-2016, 07:55 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Option
If you just want to increase rotor size to 14", it may just make sense to keep the kit you have and just buy new rotors. Then all you need to sell is your 13" rotors.
To do this you just need the (4) longer 3.15" caliper bracket studs (vs. your current 2.5") & the (4) .42" spacers that go onto the studs that space your caliper up correctly over the 14" rotor. Then of course the rotors.
I did not see the spacers offered through Summit, but could get from Wilwood. I may have some laying around as well. If I do I will mail to you if you decide to go this route... or I believe a stack of 3/8" AN washers works the same.
http://www.summitracing.com/parts/wil-230-9079
http://www.summitracing.com/parts/wil-160-8397-bk
http://www.summitracing.com/parts/wil-160-8396-bk
Jay
Old 03-12-2016, 04:16 AM
tubbed69's Avatar
Jay
Thanks Jay I will do this if that works,I called Wilwood yesterday and they told me I had to buy new brackets for each side and they wanted $214 each for brackets and price of rotors.If you have spacers let me know and I will pay you for them.I am going to Jegs today and I can check with them on studs or I will order from Summit.I really thank you for the imfo,big help.
Old 03-12-2016, 06:14 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Same kit
Ya I have the same kit and I can space different rotors from 12.5s up to almost 15" with adding spacers
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 03-12-2016, 07:22 AM
I just checked my "bone pile". I did not have any of the Wilwood spacers in that size. Again, no real need for the actual "Wilwood spacers", as a stack of washers with the correct i.d. & o.d. is just as effective.
Note: I was incorrect on specifying the use of 3/8" AN washers to do this. I was going off memory, and the AN washers are used along with the 12 point nut to fasten down the caliper. The washers you will need will have the 3/8" i.d. and an o.d. large enough to max out the "seating bore" in the caliper to better help stabilize the caliper.
Glad this info helped. From my own experience in past, it was quickly realized that thre is ZERO resale value on aftermarket brake kits.
Good luck!
Jay
Closed Thread
