Old 04-11-2016, 03:45 PM
RPitts's Avatar
RPitts RPitts is offline
Great fab work on the vents! Did you fab up the LED tail lights?
1968 Camaro LS3
1969 COPO 427
2013 ZL1
Old 04-11-2016, 05:13 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
I did, then set them in potting epoxy to protect everything
Old 04-11-2016, 06:37 PM
Originally Posted by CamaroAJ View Post
I used the DeVille wiper transmission arms and ball studs to get rid of the stock steel clamp so that the system operated quiet and smooth. I did it almost 4 years ago so I don't remember all what I had to do other than shorten them and twist one of them. I do remember that I built the whole system using the stock long arm cut in half and installed it onto the car and welded a rod between the cut parts to get the correct arm length. You can kinda see it on the top arm on the left side of the first picture.
AJ, are the part the wiper arm connects to ( not sure of what they call it) still the Camao part or are they Deville too?
Old 04-11-2016, 06:50 PM
CamaroAJ's Avatar
The ball studs? They are Deville. The arm mounts are Camaro. If I remember right they just knocked out from the back side like they are pressed in then I welded the Deville ones back in. If you do this swap like I did when you get everything you'll see how much bigger the newer parts are vs. the old stuff.
Old 04-12-2016, 01:48 PM
jamminj007's Avatar
jamminj007 jamminj007 is offline
Default color
I like that color of blue. What is that?
Jonathan
69 Camaro Fikse wheels ridetech suspension so on and so on under construction
Old 04-12-2016, 03:50 PM
CamaroAJ's Avatar
Jonathan
Electron blue metallic. Its a C5 vette color.
Old 04-24-2016, 04:43 PM
CamaroAJ's Avatar
My car showed up last week and it was good to play with it a little after not seeing it in about 20 months. Started by bolting the trunk lid on to check figment. Not too bad but will need some metal work to fit like it should.
As I sold the engine and transmission as soon as the car got here I got to work rough cutting the area for the LS7 oil tank
And since I'm going with a different transmission the trans mount had to go as well.
Since all my fab tools aren't at work yet I started to make patterns for the fuel fill that I stole from ironworks and the diff cooler I stole from hellfire
To wrap things up on this update I bought a new toy to help build some higher quality parts with. The rest of the dies showed up after I took the picture so now I have a full rack
Old 04-24-2016, 06:47 PM
frankv11's Avatar
frankv11 frankv11 is offline
Aj this is some impressive work your doing , it's going to be over the top cool ..
Old 04-25-2016, 10:55 AM
Nice update AJ. Nice new toy too.
Old 04-25-2016, 09:30 PM
CamaroAJ's Avatar
Thanks guys. Hopefully someday I'll be able to drive this thing.
