Old 04-20-2016, 06:45 AM
cpd004's Avatar
cpd004 cpd004 is offline
I'll have to double check that. I thought I tightened them up tight, but not too tight so that there would be bind. I just may have them a little too loose.
1971 Firebird
2017 SS
Old 04-20-2016, 07:37 AM
cpd004's Avatar
Here's another pic I uploaded a while back. I'm suspecting the arms are too loose.
1971 Firebird
2017 SS
Old 04-20-2016, 12:18 PM
No torque spec given but:
5. Tighten cross shaft nuts enough to create a drag on the delrin bushings, the arm should still move.
What I am seeing is tighten the nut @ ride height till the slack is taken up on the washer. 1/4 turn past. Retest.
Old 04-20-2016, 12:48 PM
cpd004's Avatar
Thanks Vince. In my #5, the instructions aren't worded like that. All I have is 'Position the suspension at mid travel and tighten the cross shaft nuts.'
I was so worried about bind, I did not tighten these enough. All 4 inner washers move freely and easily quite a bit. This is hopefully the source of the loose clunky feeling I have. I'll have to double check the rear as well.
1971 Firebird
2017 SS
Old 04-20-2016, 12:54 PM
Strange!! Be nice to have an actual torque number too. We like a reachable goal.
Also remember that the front support weight is 500 + LBS and don't go by what you can lift or push down on when gauging actual bind.
That clunky feeling you are experiencing maybe the harshness from the heims in the coil over mounts. There is very little give in them as rubber has.
Old 04-20-2016, 01:08 PM
cpd004's Avatar
They appear to be rubber on mine if I'm not mistaken. Wonder if that would make a difference in how tight it should be.
1971 Firebird
2017 SS
Old 04-20-2016, 01:13 PM
sorry, I meant on the coil over mounts. Top is usually delrin and the bottom is a metal heim ball.
