Old 05-25-2016, 05:04 AM
Graham08's Avatar
Graham08 Graham08 is offline
Very cool that you're showing the process involved in designing the SPEC chassis. We demo'd a FARO arm with the laser scanning capability at work a couple weeks ago, but the laser is overkill for what we do. Very nice piece, though.
Old 05-25-2016, 05:44 AM
grendel grendel is offline
In for the ride.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 05-25-2016, 07:58 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Using the Faro Arm, followed by many hours of 3D modeling, we produced an exact 3D model of the underside of the car. Having this model we could then plug in our suspension, engine, and trans models and start designing the frame to contour around the factory floor. There was an extensive list of goals that we set out to accomplish on this chassis design. In addition to our internal suspension geometry and performance goals the big points that we aimed for were:
  • An affordable price point under $10,000 for a complete chassis with suspension. (Brakes and 3rd member are additional)
  • A true, simple bolt-on chassis with out any floor modifications.
  • Much need strength upgrade that structurly ties the entire car together
  • Low, aggressive ride height
  • Keeping the frame rails tight to the body so nothing was hanging below the car.
  • Ability to work with all of the different LS engine and transmission combinations
  • Ample clearance for exhaust
  • Accommodate a 345 rear tire (when mini-tubbed)
There are currently 9 other 1st Gen Camaros in the shop which gave us plenty of data to compare across all cars. We were able to design a complete chassis that was 100% bolt on with zero body modifications. We added additional body mounts that bolt into existing holes and/or mounting points on the stock Camaro body for added strength and support.
Here are some screen shots of the completed chassis design under the Camaro floor model.
www.roadstershop.com
Old 05-25-2016, 08:30 AM
califconstruct's Avatar
califconstruct califconstruct is offline
Wow, that's amazing..!
Old 05-25-2016, 09:54 AM
Dave95z28 Dave95z28 is offline
What's the weight of the Spec Frame/Suspension compared to a stock sub, leafs and maybe subframe connectors?
Does it add much weight?
Dave
Old 05-25-2016, 11:06 AM
Zoomin Zoomin is offline
Love the concept. The 1st gen Camaro's really leave a lot to be desired in the chassis department.
1964 Lemans
1966 Skylark
1969 Camaro
Old 05-25-2016, 03:18 PM
Great looking drawing. What size exhaust will it alow ?
Old 05-25-2016, 07:17 AM
bikerman9967 bikerman9967 is offline
they are but cant hold accuracy under .007 it seems. for cars they are overkill
