06-02-2016, 02:47 PM
Originally Posted by 214Chevelle
My wheels are larger and taller than anyone has mentioned on here and I don't have any issue with clearance, etc. I'm running a 20x9 up front and it turns normal without any rubbing whatsoever. I think you would have been safe with the 9" wheel.
Agreed. Front control arms play a huge role here. With stock arms, forget it. I had CPP on the front of my car that limited how much backspace I could run. They were similar to stock arms, but not as restrictive. With my new Global West front arms, I have no restrictions with back spacing. I have an 8" front wheel, but I can FOR SURE go in another 1.5", and still not hit frame, sway bar, etc.
06-04-2016, 08:56 PM
That's good to know, I'm building a 71 Chevelle and I'm running UMI upper and lower control arms, I was wondering if I could have run a wheel with less backspacing than the stock arms would allow.
06-05-2016, 05:57 PM
I'm also at a point of needing a tire/wheel setup for my '69 Chevelle.
I run the Speedtech ATS front forged spindle and GW tubular upper/lower control arms.
I would love to run a 315/30/18 at all corners....
Aside from trimming the front fenders were there any mods to the rear? ie frame rail or 1/4 panel lip mod?
07-06-2016, 11:13 PM
A month later.... anyone ran 315's at all corners? What is needed to be done for body mods?
07-08-2016, 07:27 PM
Didn't Scott Mock do this on his Chevelle? Perhaps I'm thinking of another car?
07-14-2016, 10:23 PM
Did you get the wheels on car yet? Would like to see how the RTS wheels look.
I think when pushing size limits you will have a mixed bag of results.
I have 18 x 9-1/2 (5.75" BS)275 tire in front and 18" x 11" (6.25") 295/35/18 in rear om my 1969 Chevelle. No issues on back but when I had 305/35/18 DR it would rub slightly. On the front I have no fender wells. While auto crossing I caught the passenger front fender with tire and got a slight kink. Lucky for me car is just in primer.
Tom
07-14-2016, 10:24 PM
Just a sawzall
Tom
| Thread Tools |
| Display Modes |
Hybrid Mode
