Old 09-25-2016, 11:16 PM
64mali's Avatar
64mali 64mali is offline
I'm not so happy with the rear though. I think the shock is too long. I have the adjustment collar all the way to the end and the car could still go a little lower. In this position the spring falls out of the upper collar if I jack up the car. I'm pretty sure I am going to need a shorter shock! Any thoughts? Here's a pic at it's current setting.
Old 09-26-2016, 04:32 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Very nice looking bracket for the rear shock. Gotta drive the car and massage the coil overs a bit then dial them in a little at a time till your satisfied. Looks great!
Old 09-26-2016, 07:23 AM
The brakes look good on there.
Old 09-26-2016, 09:03 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
What stroke shock is that? 4.1"?
What it most important is the travel of the shock when its at ride height. If its a 4.1", you want to be close to the center of stroke so ~2" or so either way. Definitely don't want to bottom it out on compression.
If you have enough shock travel at ride height, you can get shorter springs. This will move the spring perch up to allow more adjustment (if you have shock travel of course) They can and will pop out when you raise the car. Not really a big deal as long as they seat back properly when loaded. My rears do that now since going to a high spring rate. I just reach up there and feel with my hand if the spring seated properly when letting it down.
The right way to fix it is move the shock mounts further apart...I know, not as easy.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 09-26-2016, 09:18 PM
64mali's Avatar
Very good info, thank you. I was afraid the springs would come off on a big dip or something. I have to crawl under and measure but I think I am about mid travel, although I will double check. I don't think I will bottom out the shock if I have a good bump stop on the rear end. I don't want to use the stock rubber ones, I was thinking of using the newer GM style progressive foam style stops. Anyone run these?
Old 05-07-2017, 11:21 PM
64mali's Avatar
It's been a while since I have been able to do much to the car. I got out there today and made new roll bar access panels, laid down some Dynamat, and mounted my battery tray. I also welded a bung into the cage and trunk floor near the battery so I could get a good ground the chassis and body. Tomorrow I am hoping to get the new fuse panel hung and battery cable routed.
old access panels custom fabricated by my local cage installer...sarcasm
Old 05-07-2017, 11:22 PM
64mali's Avatar
new access panels and battery bracket
Old 05-07-2017, 11:25 PM
64mali's Avatar
After cleaning things up and getting down some Dynamat.
Old 05-07-2017, 11:27 PM
64mali's Avatar
I still need to rivet down the access panels. I welded 3/8" bungs to the bottom of the battery tray and it's bolted down from underneath. I think it came out pretty clean.
