Old 02-07-2017, 06:31 PM
carbuff's Avatar
carbuff carbuff is offline
Default Source for tow hooks?
Currently I have 3 tow hooks on TOW: one front, and 2 at the rear axle shock mounts. I am likely going to replace the front one, and I need to add a new rear one. So I'm looking for a source for them.
The place I purchased my current ones from appears to be out of business. Anyone have a good suggestion, particularly for a 2nd gen F-body?
Here is what I currently have:
Old 02-08-2017, 03:38 AM
Tim john--- Tim john--- is offline
DSE offers them I believe.
Tim john---
Old 02-08-2017, 05:41 AM
rickpaw rickpaw is offline
I've been eyeing the tow hooks from Rennline.
http://www.rennline.com/Hooks/products/663/
Tu Ho
Old 02-08-2017, 08:44 AM
Ron Sutton's Avatar
We carry "a few". 1 bolt on, 1 weld on & 1 clamp on. None are car model specific.
Look HERE.
Ron Sutton Race Technology
Old 02-08-2017, 10:55 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
^^^^ Man, those are sweet!! ^^^^
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-08-2017, 12:44 PM
Che70velle's Avatar
Bryan, I don't have any info regarding hooks, sorry. How is the engine working out? Did you get your oiling issues under control?
And I have to ask...that line you have going under the rear frame rail...what is that?
Thanks Dad!!
Old 02-08-2017, 03:19 PM
Yep they make nice ones!
Old 02-08-2017, 07:22 PM
Ns RS's Avatar
Ns RS Ns RS is offline
Rennline is a quality piece, folds out of the way, here it is mounted
Old 02-08-2017, 07:28 PM
carbuff's Avatar
What do you have that screwed into? Unfortunately the Firebird doesn't have a nice opening like that to make life easy. :\
Old 02-08-2017, 07:33 PM
carbuff's Avatar
So far the engine seems to be doing well. I got her up and running late summary and went to the Fall GG. I haven't driven a lot since then due to work travel, but I have an autocross next weekend I may attend, and a 3-day event at COTA the weekend after where she'll get a real test!
I need to dyno again, I have an appointment next week for that. Strangely my timing seems to be off after the rebuild. That was one thing which was found during the rebuild: the reluctor ring had spun. When I started driving again after the rebuild, I was getting a good bit of detonation, so I backed the whole timing table off about 3*. We made a timing tab which shows that's about how far we're off. So the dyno will help dial that back in.
I'm really happy with the current oiling solution, but I have to say that seeing 10 psi of oil pressure when hot is a bit unsettling at first! I'm told this is normal, and the pressure jumps as I expect with RPM. Still, something to adjust to!
As to your other question, that is the brake line. With the DSE subframe connectors, there isn't a good 'opening' to tuck it up any better. Eric did a nice job with it, but yes it's below the rail...
