Old 02-11-2017, 08:38 AM
Build-It-Break-it's Avatar
I personally think your steering column is still to long. If you look at Roger's column from speedtech below you can see it sticks out far less then yours. Maybe they sent you a 34"column instead of 32" (assuming a length I'm not sure) ? If the column was further in the angle would change and your steering shaft would work. I'd measure your column.
Ahmad B
