Old 02-12-2017, 01:42 PM
I'd block the oil filter bypass. All that wear you see is being pumped through your bearings when the engine is cold. I bet your main bearings are toast.
Old 02-12-2017, 03:41 PM
TBART70 TBART70 is offline
Main bearings are fine, bypass is plugged.
Old 02-12-2017, 07:18 PM
That's good news.
Where you take the oil pressure reading also effects the perceived pressure. 15w50 would likely get you to 20 psi at idle and 60 at wot hot. That is plenty in my opinion.
Old 02-13-2017, 03:41 PM
I tried 15/50 didn't help. Pressure taken by three different gauges. Did some more checking, seems to be a distributor/intake height/oilpump and shaft issue.
Old 02-13-2017, 05:00 PM
I've seen that before. Something to ALWAYS check before sticking the pan on etc.....
Old 05-26-2017, 05:53 AM
dcrider69 dcrider69 is offline
I run 20w50 in my big blocks.
Always have, always will.
Simple Castrol conventional, never had pressure issues.
