Old 04-03-2017, 08:39 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Found this on LS1 Tech, I used the stock hardware and this seem right. I believe Home Depot or Lowes will have these in the parts bins.
M10x1.50x40mm long. I ordered mine from Mcmaster Carr.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 04-04-2017, 04:35 AM
paulk68 paulk68 is offline
Thank you Very much!! did you happen to put a washer on there also?
Old 04-04-2017, 09:14 PM
DEIGuy38's Avatar
Yes, i used flat washers on mount to transmission and lock washers at cross member to mount. See the attached from energy suspension
https://www.summitracing.com/parts/e...FQRsfgodfFoN8w
Guy
