Old 04-20-2017, 08:52 PM
That's good market awareness! On that note, from what I've experienced, it's always frowned upon to put thread tape on brake fittings . . .
On another note, I've seen brake system leaks go away with usage (heat & expansion), which can be hard to apply with a minimally used fun-car . . .
Good on Wilwood (I have their stuff, too!) for stepping up and trying to put the fire out!
Old 04-20-2017, 09:21 PM
Bad master seat or line flare, what else could it be?
Old 04-21-2017, 06:39 PM
vstol vstol is offline
The Teflon tape for the adapter going into the MC is Wilwoods recommendation, it is not on the brake line. I tried 4 brake lines (store bought not made) and it still leaked. Something was just a little off (milled)
Old 06-10-2017, 11:17 AM
speed_m5 speed_m5 is offline
never use thread tape on aluminum it acts like lube and you will split the bore
Old 06-11-2017, 03:41 AM
Thanks but as mentioned it was Wilwood recommendation. Got a new MC and it looks like I have it fixed
Old 06-11-2017, 05:50 AM
dhutton dhutton is offline
Glad you finally got it fixed.
