Old 07-16-2017, 07:32 PM
JKnight JKnight is offline
Can you flip the shifter cable bracket over so the bend in the bracket jogs away from the header rather than towards it?
Old 07-16-2017, 08:02 PM
No the lever has holes for three types of transmissions and of course mine is the furthest towards where the problem is, all the way to the front.
It's the top hole (in pic) on the square end which faces forward.
Old 07-17-2017, 04:56 AM
TomM's Avatar
TomM TomM is offline
Looks to me like that is your o2 sensor bung....correct? No amount of spacing will give you the room to clear the sensor. Best thing to do is relocate the sensor to clear...and have the headers re-coated....
The oil cooler line looks fine to mew, you have heat shielding on it.....it should be good...
T,
Old 07-17-2017, 05:18 AM
Tom, that bung will be capped off its already move to the ther side of the header. On the hoses it is so tight we made a sheet metal shield you can feel it touch when sliding in.
Old 07-17-2017, 07:49 AM
TomM's Avatar
I see it now, it's the hose in the back. Can you source a 45 degree fitting to extend the front one down and at an angle to angle away from the rear one?
Something like this.... http://www.jegs.com/i/Earls/361/AT924110/10002/-1
What size are your oil lines?
As for the shifter bracket, I would take a BFH and straighten it out to give you clearance if you can do so.
T,
Old 07-17-2017, 08:50 AM
Tom My oil lines are -12 . where you see it is the place with the most clearance to get it to the front. I can't go below the tube because it ends up below the oil pan. I should have made the oil lines for the first 10" out of stainless or aluminum that would have made more room anmd aluminum could have been welded to the pan adapter without fittings.
1Bad68Cat
Even with the BFH it still doesn't have enough room. It would need to be offset in the opposite side 1/2"-3/4" I don't want to change the geomitry of the bracket.
Old 07-17-2017, 12:31 PM
TomM's Avatar
Tom My oil lines are -12 . where you see it is the place with the most clearance to get it to the front. I can't go below the tube because it ends up below the oil pan. I should have made the oil lines for the first 10" out of stainless or aluminum that would have made more room anmd aluminum could have been welded to the pan without fittings.
1Bad68Cat
Okay...got it. So, on the front fitting, is there a way you can turn it slightly outboard of the engine, and then put a 45 degree fitting on it instead of straight so it can point down slightly and run outboard alongside the rear line?
How much can you grind off the O2 bung and still get a plug in there? If you aren't comfortable bending the shifter bracket inboard, you may have to grind the bung off completely, seal the hole and re coat the headers. I would think you could bend the bracket inboard.......
T,
Old 07-17-2017, 05:56 AM
1Bad68Cat 1Bad68Cat is offline
How about trying to re-bend the bracket? Use a vise/hammer to straighten then make the jog the other way.
Robert Icasas
Projects:
67 Cougar
Art Morrison Sport IFS
3-link Rear Suspension
Coyote w/ D&D Performance Viper t56
Build: https://lateral-g.net/forums/showthread.php4?t=50170
Brother's 1966 Mustang Restomod
Mustang II front suspension
Torque Arm Rear Suspension
Ridetech Shockwaves
5.0 w/ Viper t56
