Old 07-16-2017, 07:36 PM
JKnight JKnight is offline
The shock mounting area/tabs of the factory stamped lower control arms aren't meant to carry the forces of the spring and shock. I wouldn't do it because it's not a very nice type of failure when/if the 45+ year old stamped sheet metal gives way.
Old 07-17-2017, 10:51 AM
dhutton dhutton is offline
What are you hoping to gain with the addition of coilovers versus lowering springs and decent shocks?
Old 07-17-2017, 12:04 PM
dwilson's Avatar
dwilson dwilson is offline
I have seen the argument for the placement on the stamp lower control arms. I'm just not sure if this changes even with a newer tubular control arms and already have a place with simple holes drilled through it for the mounting.
Adjustability of up-and-down of the ride high is very enticing along with the double adjustable coil overs offered customizable options
Old 07-17-2017, 02:16 PM
rickpaw rickpaw is offline
This. If you look at the mounting hole for the shocks of the stock lower arms, the metal is quite thin. The QA1 set up places the entire front end weight on the thin spot, rather than spreading it out within the spring pocket.
Any quality aftermarket arms set up for coil overs will have the mounting area enforced with thicker metal.
Don't take our words for it, take apart the stock lowers and see for yourself.
Tu Ho
Old 07-17-2017, 07:59 PM
Tinker's Avatar
Tinker Tinker is offline
This is one situation saving around five hundred bucks isn't even close to being worth the risk. Sure, it bolts together, but save your pennies and do it right instead of risking the well being of you, your passengers, and possibly even bystanders.
Chris
Old 07-18-2017, 07:58 AM
BMR Sales's Avatar
I would not use the QA1's with the Stock Stamped arms.
Save up & do it right!
Old 07-18-2017, 09:28 PM
dwilson's Avatar
You guys definitely have a point.
