Old 11-06-2006, 12:11 AM
Project_Gotham Project_Gotham is offline
Default teardown the 406, I get 2-surprises
Ok so I order new ceramic headers and flowmaster American Thunder system for my 406ci Edelbrock EFI 72' Camaro SS. A bad surprise turned into 2 good ones!
Well after removing the old hooker headers I noticed that some of the bolt holes for the headers are stripped. So I tear off the intake to remove the heads to get them repaired. As soon as I pull the intake I see Retro-fit Roller lifters. I scream out " It's a roller motor"!
Some of you might remember me posting about converting over to a roller cam. Well all i have to do is order the roller cam I want now.
Surprise #2:
I noticed when I removed the valve cover that the heads had canted valves like a big block. I cannot find a name on the heads but I do have serial numbers on them. I took them to a local speed shop and they were speechless, they said that they have never seen such a drastic offset on the intake valve(said looked like 10 degrees), but told me that they are probably trick-flow twisted wedge race heads, or AFR's. I will post pics tommorow of them. Maybe some one can indentify them.
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 11-06-2006, 09:38 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Cool!
Yeah, they're probably TFS heads.
I don't think AFR made a non 23* head for sbc.
Post the numbers off the heads.
Old 11-06-2006, 05:09 PM
rocketman's Avatar
Could be Dart or Brodix
Old 11-06-2006, 11:23 PM
Here are the numbers: Maybe someone can help
head 1: SN 14901
head2: SN 14617-14666
I'm getting them rebuilt .I have no clue why someone painted them??? Sorry about the crappy pics. will take more during the day.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
Old 11-09-2006, 03:27 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
"I scream out " It's a roller motor !
hopefully not during sex.
Jim
Old 11-09-2006, 07:03 PM
rocketman's Avatar
Look like Gm Bow-tie heads
Old 11-15-2006, 06:35 AM
KUL FIR CHICK N KUL FIR CHICK N is offline
Default canted valves
Those are trick flow twisted wedge heads. I'm not positive, but I don't think they make the twisted wedge heads anymore. They were a pretty good street head, but I think the geometry destroyed valvetrain parts.
Old 11-15-2006, 01:46 PM
DaCajun DaCajun is offline
Yep,
Those are Trick Flows for sure. I had a brand new set of them and sold them. Not a bad looking head but needs a special piston to work right. Here's what new ones look like.
-Dave
Old 11-15-2006, 05:32 PM
Thanks for helping me out DaCajun. What kind of piston does it take ????
I had the heads redone. I will post pics when I get them back ,soon I hope. They had a couple of slightly bent valves. They had to have a company custom make them due to they're irregular short stem.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
