Old 11-06-2017, 08:03 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Did it not make it to OSCI ?
Old 11-06-2017, 01:19 PM
Haulin-A Haulin-A is offline
Glad I got to see this car in person. It was definitely one of my favorites in the Optima Invitational lineup.
Old 11-06-2017, 01:24 PM
carbuff's Avatar
carbuff carbuff is offline
I was wondering the same. I see his name in the participant list, but he didn't score in any events, so I presume he didn't run?
Old 11-07-2017, 04:34 AM
Stielow's Avatar
Stielow Stielow is offline
The car developed a radiator leak on the way to SEMA. I chose not to try putting goo in the radiator. If it fixed it I would have to flush it out. If it did not work I still would need to fix it and flush it out.
The safest thing to do was bow out and fix it correctly.
Mark
Old 11-07-2017, 05:14 AM
NAPA 68 NAPA 68 is offline
Mark
Bummer..............good call though!
not that you need any of us to tell you that.
Old 11-07-2017, 07:11 AM
carbuff's Avatar
Mark
Agreed, although sorry to hear it...
Old 12-28-2017, 03:47 PM
At last.....................a bunch of pics!
http://www.superchevy.com/features/1...g-1969-camaro/
Old 12-28-2017, 04:47 PM
Build-It-Break-it's Avatar
Thank you for posting that. Very cool
Ahmad B
Old 01-23-2018, 05:53 AM
stan65 stan65 is offline
Mark,
First of all Love your cars! Hope to see a DETAILED build on this car!
I am an the midst of installing an LT4 in a 71 Firebird. I see you went vacuum brake booster for the brakes. The instructions that came with the LT4 said use a vacuum pump as using a vacuum brake booster will have issues under boost?
What did you do? Pump or no Pump? If you used a pump which one did you use?
Thanks,
Stan
