Old 12-18-2017, 04:22 PM
bullittcustoms bullittcustoms is offline
Default LSx Engine Wire Routing
Hey Guys, Where is everyone going through the firewall on the engine and pedal harness? And what about the seal? I have the GM controller, so the fuse block is pretty big. Was planning on putting it behind the ash tray, but where on the computer is good? Just looking for options.... TIA!
Derek
Old 12-21-2017, 08:38 PM
Nova939 Nova939 is offline
I made a hole right behind passenger head, just above the factory ribs in the firewall. I can shoot you a pic if you give me an email. I have the gm harness as well and it worked out perfect. I ended up finding a grommet in the junkyard from a Toyota from the door jamb harness, it was exactly 1.5 inch which was exactly the size hole I made in the firewall. I cut and taped it into the harness, worked out great.
Old 12-22-2017, 07:56 PM
randy randy is offline
Speertech gromet more drivers side head behind the motor which keeps it away from the vintage air unit
Old 12-31-2017, 11:07 AM
Man a pic would be awesome!! [email protected]
Thanks!!
Old 01-01-2018, 05:59 PM
simbad's68 simbad's68 is offline
Here's a pic of my GMPP LSA harness running through the firewall.
Old 01-02-2018, 11:06 AM
Man that looks clean!! What size grommet is that and where did you get it?
