Old 11-14-2006, 08:09 PM
Clsccmro's Avatar
Clsccmro Clsccmro is offline
I have the exact unit you've pictued MaxHarvard from painless, and the unit in my eyes is perfect. It's inexpensive and very simplistic to wire up. They include plenty of wire for the unit so that you can mount it in just about any location. I am strictly using the unit as an under-the-hood accessory hook-up. I just installed it about 3 weeks ago, and there are no complaints here. I have 2 electric fans connected, along with MSD ignition box, electric water pump, and electric starter. The only complaint I have about the unit is that all of the wires run directly out of the back side of the unit, and it makes it a little difficult to mount to a surface. However, they provide long bolts which allow you to tighten it down to a surface using the bolts rather than forcing it with your hands. I highly recommend this product.
Old 11-15-2006, 04:47 AM
MaxHarvard's Avatar
Originally Posted by PRRC
MaxHarvard,The highway 22 is made by American Autowire. It is one of there universal kits. We like them because of there versatility.It comes with all the switches ignition /headlight /dimmer and all the pig tails for headlights/ GM turn signal for your column.pretty much everything you need to do a complete rewire.Not sure what kind of car your redoing but these kits work great. If you need some more info feel free to give use a call we will be happy to answer any questions you may have.
Tim Paradise Road rod & custom Indianapolis.IN.
phone 317 541-9590
Ahhh ok i see. I'm only looking for a supplemental wiring harness, the car has been totatlly rewired from top to bottom with OEM replacement stuff. I just need something to help me clean up some of the hideous looking wires under the dash and under the hood.
Clsccmro: Thanks for the info, i was hoping someone had actually used it. Where did you mount it? I'm thinking in the glove box or something like that.
