Old 11-14-2006, 11:01 AM
MaxHarvard's Avatar
Default Painless wiring question...
has anyone used this before? How hard is it to wire up? does it work well? I'm running out of room for 12v hot and key-on hot wires.
Please, any help would be good!!
http://www.jegs.com/webapp/wcs/store...20007_-1_39983
Old 11-14-2006, 11:08 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Eric, check out American Autowire. They might have something that will work for what you need.
edit: Found the link:
http://www.americanautowire.com/prod...ccessories.cfm
My LS7 69 Camaro
Old 11-14-2006, 11:19 AM
MaxHarvard's Avatar
Can you tell me which one you were looking at?
Whats the difference? I need one with 12v Key-on and 12v constant HOT.
Old 11-14-2006, 11:30 AM
XcYZ's Avatar
In that case, you'll want one with 2 busses, American Autowire's accessory blocks have one. You could use two accessory blocks, one for 12V constant and one for 12 V ignition. I see that the accessory blocks from Painless are setup with 2 busses.
My LS7 69 Camaro
kennyd's Avatar
kennyd kennyd is offline
painless is a easy to use harness .
are you talking about at the key ? thats where you are running out of wires ?
Old 11-14-2006, 01:23 PM
MaxHarvard's Avatar
I'm talking about 12v sources that need the key to be in the ON position, and some sources (like the CD player) need a constant 12v source when the key is in the OFF position.
Old 11-14-2006, 03:22 PM
kennyd's Avatar
ok i understand . i set up a relay on a junction block for keyed wires and run a constant junction block for non keyed 12v .
i like painless harness , but i have a AAW set up for the 57 i will see how i like it .
Old 11-14-2006, 04:25 PM
PRRC PRRC is offline
We use and sell the AAW kits. we like the AAW kits because they are upgradable. You can add to them without having alot of extra wiring you arent using. Say for instance you deside later to add A/C to your car. the accessory outlets are already in place to do so. You can add the wiring as needed. The highway 22 also has previsions for an electric fuel pump with a built in relay. There is more than plenty of 12v constant and keyed outlets to fit just about any needs you may have.AAW classic updates are great for a guy that has updated some of the electrical compaints like ignition and radio.But wants to keep the gauges and instrument lighting.Its a very well thought out system. Tim
Old 11-14-2006, 07:05 PM
MaxHarvard's Avatar
PRRC.... which one are you referring to? I cant find the Highway 22.
Old 11-14-2006, 07:38 PM
MaxHarvard,The highway 22 is made by American Autowire. It is one of there universal kits. We like them because of there versatility.It comes with all the switches ignition /headlight /dimmer and all the pig tails for headlights/ GM turn signal for your column.pretty much everything you need to do a complete rewire.Not sure what kind of car your redoing but these kits work great. If you need some more info feel free to give use a call we will be happy to answer any questions you may have.
Tim Paradise Road rod & custom Indianapolis.IN.
phone 317 541-9590
