Old 09-02-2018, 12:18 PM
Brianstanford Brianstanford is offline
Well after some reading I decided to take the head off and just have a machine shop fix me up. Read good things about Late Model Engines in Houston. Cool, no big deal getting the hole repaired. So I get the head off and see bunch of rust on the cylinder walls. Guessing hurricane Harvey waters sitting in the garage for a week got moisture in the motor through the exhaust ports, they just had rags stuffed in them. I've had enough of this for today lol. Time for a gun range trip to relax
Old 09-02-2018, 12:19 PM
Motor is a 70k mile LS2 from a 07 corvette
Old 09-04-2018, 02:51 PM
Cleaned on the motor today. Will do more once I start putting the top end back on
Old 09-05-2018, 10:43 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Just as a tip to help you prevent some flash rust in the cylinder by taking a clean rag and putting some Automatic Transmission Fluid on it and wipe down the cylinders liberally.
Build looks great! Hopefully, my car will be up and running in the next 5 months and we can get some cruising done!
Gray
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
The Following User Says Thank You to BigBronco For This Useful Post:
Brianstanford (09-06-2018)
  #55
Old 09-06-2018, 08:33 PM
LME out of Houston got me fixed up with a heli coil
Old 09-06-2018, 08:35 PM
Heads back on and motor off the stand. On a cradle stand now so I can get the ls7 clutch kit installed
Old 09-06-2018, 08:49 PM
Was there water in the crankcase?
Old 09-06-2018, 09:44 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Way to stay with it Brian.
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
Brianstanford (09-07-2018)
  #59
Old 09-07-2018, 10:12 AM
No there wasn't. Everything was very clean when I had the oil pan off to install the holley pan
Old 09-08-2018, 11:28 AM
Pilot bearing in. LS7 clutch on. Bellhousing on. T56 ready with slave and quick bleed line
That's all for today. On graveyards this weekend
