Old 10-08-2018, 02:55 PM
Brianstanford Brianstanford is offline
air intake. 4'' spectre tube, summit silicone hose couplers and a 7'' airaid dry filter
Old 10-09-2018, 05:34 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Hard to tell if the intake tube is in front of the fan or not. It looks very similar to mine and i had to raise mine up above the fan. If it is in front of the fan it will get heated when the fan is on. Problem being is the mass air is reading the incoming air temp and the air gets heated directly after the mass air. It could cause a spark knock because the ECM thinks the air temp is lower. Any-who something to think about.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
The Following User Says Thank You to Jimmy Sean For This Useful Post:
Brianstanford (10-10-2018)
Old 10-10-2018, 09:53 AM
Thanks! It is in front of the fan a little bit. Didn't even think of heat soak on the intake tube.
Old 10-11-2018, 06:04 AM
F'in mine's Avatar
This might help in keeping the intake tube as cool as possible......exhaust wrap, plus if you're not into polished aluminum look it tones down the shininess of the tube with a few colour options.
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
Brianstanford (10-12-2018)
Old 10-11-2018, 02:06 PM
Jimmy Sean's Avatar
Not sure I'd do that, wouldn't it heat soak and then take longer to cool? The heat reflective tape, the gold or silver work better at reflecting the heat?
Old 10-12-2018, 03:50 AM
i was thinking about the gold or silver tape, wish it came in black
Old 10-16-2018, 12:09 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Great looking build Brian! You've through quite a bit of life's trials and tribulations during this process. Enjoyed reading your thread. Way to keep at it!
Brent
The Following User Says Thank You to Ricochet For This Useful Post:
Brianstanford (10-17-2018)
Old 10-25-2018, 04:30 PM
glassman's Avatar
glassman glassman is offline
I used self etching primer on mine. Then rattle canned it matte black. Both sourced from a body shop paint supplier.
https://lateral-g.net/forums/showthr...assman&page=48
post#472
Mike
The Following User Says Thank You to glassman For This Useful Post:
Brianstanford (10-26-2018)
