Car looks good. Once you get it dialed in, it oughta be great in CAM.
Noticed the NE plate. Would be nice if you posted your location in your profile. I'm originally from Gering. Now in Chandler, AZ doing autoX with AZSolo.
Saw your reply over on Lance's thread. Replacing the body mounts with some stiff aftermarket ones, patching the rusted frame holes( I'm sure some are bad . They usually are. ) and maybe even boxing the frame rails should make a huge difference. If you look on Chevelles.com, there used to be a thread or two on making a simple body brace between the rear wheel wells( sort of an "X" behind the back seat using 1/8" flat strapping).
Ric
