Old 11-23-2018, 09:15 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
I noticed you are using an F-body oil pan. Did you have to do anything to keep the inner tie rods ends from hitting it at full lock? Have you thought of using the roadrace baffle for inside the pan. I think there is one available for the stock pans as well as the Holley pans.
Ric
Old 11-24-2018, 06:57 PM
Che70velle's Avatar
Cool car. What rear bar are you running? Car will likely turn better with softer rear bar. Stiffer rear bar unloads inside tire too much, hence the wheel spin.
Thanks Dad!!
