Old 11-03-2018, 12:29 PM
Nice
Old 11-21-2018, 02:56 PM
syborg tt's Avatar
I love the jack stand idea.
marty-mj
Old 11-29-2018, 12:58 PM
Goosesdad's Avatar
Amazing write up! Thanks. They looks great, always amazing work.
Originally Posted by MtotheIKEo View Post
Not a bad idea!
Great idea! I run into this issue when lifting my TA for the exact reasons you mentioned.
Nice
[QUOTE=syborg tt;686373]I love the jack stand idea.
Thanks guys. I did add some bracing that "sorta" connected the front jack stand points to the roll cage. The area I welded this to is basically the front connection point for the subframe and I added an additional 1/8" plate to distribute the load so it was carrying the load as close to being connected to the subframe/roll bar as possible. I didn't take great pictures of this process but essentially I cut through the floor to expose the backside of the subframe mounting plate (there is a hollow area here). My 1/8" plate is welded directly on top of that mounting plate. I then hand fabbed some 3/16" steel into a box and welded it to the plate, the floor and then finally to the roll bar. The stronger approach would have been to run a roll bar directly from the front roll cage bar straight down to this point but it would have not allowed for any room for my left foot next to the clutch and I think that would have been very uncomfortable while driving. Compromise but I think I reinforced this area enough that it should be more than strong enough to support the car on stands/lift.
The rear point is essentially directly connected to the rear frame through the lower 4 link connection point. I believe this should be very strong and easily support the rear while on stands/lift. I have put it back on the lift using these points, albeit just the body, and all worked great.
All of this is a bit of added weight but less than 10lbs total and I think the added functionality is worth it.
Have a great day!
John
My Build Thread:
Old 11-29-2018, 01:00 PM
Goosesdad's Avatar
Insignificant little rust repair on the bottom of the door.
Have a great day!
John
My Build Thread:
Old 11-29-2018, 01:05 PM
Goosesdad's Avatar
I've had the door bars sitting on the shelf for a couple years thinking I would help my old bones from having to crawl over them 7 bazillion times but decided it was time to cross this off the to-do list. I did save about 3 bazillion trips...!
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (12-01-2018)
  #276
Old 11-29-2018, 05:13 PM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
I cant even imagine the amount of time that has gone into this amazing build so far. This wil be one bass ass car when its done. 👍
1970 Camaro Build Thread https://lateral-g.net/forums/showthread.php4?t=54602
The Following User Says Thank You to Sandro's 1969 502 Camaro For This Useful Post:
Goosesdad (12-16-2018)
  #277
Old 12-16-2018, 08:39 PM
Goosesdad's Avatar
Engine bay bars welded in, will put the top tube in later.
Silly detail here but this stamped cowl support flexes quite a bit at the bottom because the factory didn't leave enough of a lip. I added a few small pieces of metal and then just a little fun with the dimple die.
Size:  148.6 KB Name:  hh4.jpg
Size:  145.5 KB Name:  hh8.jpg
Installed the hood latches.
Lots of work ahead of me to get the gaps tightened up.
Have a great day!
John
My Build Thread:
The Following 2 Users Say Thank You to Goosesdad For This Useful Post:
alex n (12-17-2018), syborg tt (12-29-2018)
  #278
Old 12-24-2018, 09:00 AM
glassman's Avatar
glassman glassman is offline
Geez louiz!!! "The foundation in this one runs deep young skywalker".
Soo good. Thanx for posting...
Mike
The Following User Says Thank You to glassman For This Useful Post:
syborg tt (12-28-2020)
  #279
Old 12-25-2018, 03:17 PM
alex n alex n is offline
Nice
Old 12-25-2018, 03:56 PM
Good fix.
