Old 11-20-2006, 11:30 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Originally Posted by deuce_454
hotchkiss suspension and poly bushings, big swaybars and quality springs and shocks.. (airbags are not for cornercarving IMHO)
Neither are poly bushings on a 4-link
Old 11-20-2006, 12:19 PM
rocketman's Avatar
Troy put 18's and 22's on Bisquick and Chicayne.
You could go 19's on the front.but 18's will look fine.Just look at Chicayne,and I am pretty sure the 66 Troy did has 20's and 22's.
Air ride has come along way I used to be one of those "air ride won't handle" guys,but this summer changed my opinion.see the autocross by Air ride at some of the Goodguys changed my mind,and the Airride cars were faster than most the coil over cars.
A 66 b-body will never be a great track car.
Old 11-20-2006, 01:50 PM
JayR JayR is offline
Lateral-G Supporting Vendor
The 66 had 20s front and rear and Chicayne and Bisquick have 19s up front
Old 11-20-2006, 03:36 PM
rocketman's Avatar
Here's 18's and 22's on a 66 Caprice.
Old 11-20-2006, 04:30 PM
No offense to Travis but that pic kinda makes my case. The rear wells are stuffed and the front wheels aren't even big enough to tuck and it has too much rake for me. But opinions are like............
Old 11-20-2006, 05:28 PM
bulldogchevy bulldogchevy is offline
Hey 96z28ss i live next to lake boone ice,moved to hudson two years ago.
In the works
69 camaro wayne due front dse rear 427 twin turbo
67 chevy 11
65 biscayne
289 fia cobra allmost done
done 66 chevelle 396 375 conv matching #
scott
Thanks for all the info keep it coming
Cant wait to spend some money
Old 11-20-2006, 06:17 PM
Derek69SS's Avatar
Why not? A B-body 2dr sedan is about the same weight as a 2dr hardtop Chevelle, and balanced better (all the extra weight is in the rear).
The only downside to building a B-body is the lack of aftermarket handling parts.
Old 11-20-2006, 06:54 PM
rocketman's Avatar
I have been thinking about my statement,wont chevelle parts work I thought they were kinda close to the same.
Old 11-20-2006, 07:03 PM
Derek69SS's Avatar
No, Chevelle chassis parts won't interchange. Everything is different.
The only "common" parts with an Impala, is that any rear disc setup that fits a Camaro/Nova/Chevelle, will also fit a B-body, and a Chevelle rear sway-bar will fit. Other than that, I'm not aware of any parts that interchange.
Old 07-18-2008, 10:11 PM
BLWN1 BLWN1 is offline
old post, but I like this...
