Old 05-03-2019, 12:25 PM
Oleyellar Oleyellar is offline
Default All of the above
Front fenders, wheel wells and frame rails. Outside rubs at the inner fender to fender attachment and flaring fenders and boxing out the wheel wells will fix that, but then inside sidewall will rub the frame at the steering gearbox location when turned. This is why ALL of the aftermarket subframes have narrower frame rails..
It can all be made to work with enough effort and metalworking skills. At least that is my experience.... I have 9" wheels and its tight in both locations.
The Following User Says Thank You to Oleyellar For This Useful Post:
DKz Garage (05-04-2019)
Old 07-02-2019, 06:52 PM
aany001's Avatar
aany001 aany001 is offline
What size tire are you running on the 9" rim? Also is it a 18" rim?
Old 07-03-2019, 07:05 AM
Default Michelin
255/35x18 Pilot Sports
Old 07-03-2019, 01:06 PM
aany001's Avatar
Could you post some pics of your front rim and tire setup?
Old 01-23-2020, 11:15 PM
Pete68's Avatar
Pete68 Pete68 is offline
Im running 275 on a 68 camaro with rolled and cut fenders (which you cant tell from the outside). Fits with lots of space on the inner area, maybe a half inch. So yes I think you can do 10in wheel. Offset needs to be spot on and tire diameter should not be too big. Im running small tire diameter 275/35-18
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
