Old 06-29-2019, 04:49 AM
dhutton dhutton is offline
Originally Posted by randy View Post
Mounting the tires is easy. Removing them in the future is the hardest part without scratching the barrel
So how do you remove the tires without scratching them?
jarhead (06-29-2019)
Old 06-29-2019, 06:50 AM
jmac jmac is offline
Are there any custom car shops that sell accessories and stuff near you? There's one near me that has some "touchless" machine from Hunter. Think the guy said it was close to 50 grand for the machine.
Anyways, my buddy had 6 new tires mounted and balanced for his 2017 Z06 for $45 each. Not a mark on them. 4 replacements for the stock wheels and a set of 19's with drag radials.
Good luck
The Following User Says Thank You to jmac For This Useful Post:
Old 06-30-2019, 06:54 AM
randy randy is offline
It’s easy if you know what you are doing. Some rims come with plastic rings around the barrel when they are shipped. I’ll keep that on there or leave the plastic on while mounting them. Removal is usually easier since the tires will come right off. When breaking the bead just add lube when the shovel head pops the bead of the tire. The hardest part is getting the clamps on the outside of the front of the wheel while facing down. You slowly position the wheel right at the clamps and have to push the center of the wheel down to expose the lip and clamp the wheel at the same time. If you miss you are pinching your tire or scratching the wheel.
All of my pro touring friends in DFW I help personally. FYI I’m a district manager for NTB in the Dallas area
Old 06-30-2019, 04:31 PM
jarhead's Avatar
jarhead jarhead is offline
Thanks all
joe
Semper Fi
My 68 Torino
