Old 07-26-2019, 11:45 AM
vstol vstol is offline
The leaf spring is an issue, hard to move and I do plan on tubbing (mini) too get the tire I want. So many companies make a kit to relocate the leaf springs as well as 4 link. Just researching
Old 07-26-2019, 02:09 PM
Heidts 4 link set up you can not mini tub so a 275 is max, Ride tech 4 link they said I could fit a 315 easily under it if I mini tub it, DSE I need a new gas tank to make it work etc.. Not sure about BMI still researching it
Old 07-29-2019, 06:25 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default BMR Torque Arm
FWIW I'm able to run a 295/40/18 on my Firebird with plenty of room to go 305/315 without a minitub and it's completely bolt-on.
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-29-2019, 06:12 PM
Any pictures of the wheels/tires underneath this set up? It looks really nice however I am looking at it and it is very tight especially without the mini wheel tubs. Thanks
Old 07-30-2019, 07:01 AM
OLDFLM's Avatar
Default BMR Torque Arm + 295/40/18
The 295s fit great with the BMR Torque Arm and I think even with the flatter wheel opening on your Camaro they would work if you look at how far inside the wheel lip the tires are tucked on my car. There's also good clearance before the tire would contact the rear of the inner wheel well on the inside. Early Firebirds don't have the seat belt bludge in the front of the inner wheel well but if your Camaro does a BFH should easily adjust for any needed clearance there.
FREEDOMBIRD
Old 07-30-2019, 05:42 PM
Thanks this really helps how do you like the setup? I spoke with BMR today and they are pretty much saying what you are and a mini tub even better. Did you keep your C-clips or go with a C-clip eliminator? I assume the stock gas tank still fits.
Old 07-31-2019, 06:35 AM
OLDFLM's Avatar
Default 10 years on BMR
Stock rear end upgraded 31-spline axles, posi, KORE3 brakes, etc.
Stock Goodmark replacement tank... 3" exhaust cleared everything... 2.5" tailpipes would be even better/easier.
I LOVE the ride with the BMR torque arm and their uppers/lowers and sway bar up front! I have AFCO coilovers front and rear... the ride is very compliant and comfortable, yet also very solid with great traction and cornering. I think it's the best of everything honestly!
You'll find other threads where the torque arm and 3/4-links are compared and for a dual purpose street/track car most all agree that a torque arm is the way to go...
My 2 cents. HTH
FREEDOMBIRD
Old 10-07-2019, 04:34 PM
Not any progress but will turn on it once the engine and drive train are sold. Not sure why the pictures are not sitting correctly. Sorry
The Following User Says Thank You to vstol For This Useful Post:
syborg tt (10-12-2019)
Old 10-11-2019, 01:13 PM
I think I am leaning twds the BMR setup
