Old 08-01-2019, 06:02 PM
carbuff's Avatar
carbuff carbuff is offline
Correct, the VFN hood buckled. The hood is made in 2 pieces, the lower which is the support structure and the top which is mostly just the top flat. They are then bonded together.
The channels that run front to back just aren't very strong, and those are what buckled. On this new one, I had VFN reinforce those internally by adding some metal to hopefully help solve this problem. But I'm gun shy...
I would expect the Anvil piece to be much better in this area.
As for the lip, are you using stock hinges right now? I would expect those to be fine.
I briefly had a set of the RB hinges which I tried, but those didn't seem to be much better. To be fair, I didn't spent a lot of time trying to adjust those. If I had to compare the two I would say the RB were a little 'stiffer' in terms of side to side movement which could be both a good and a bad thing. It's harder to adjust / install if there is too much stiffness. But they were a nice piece. The other issue was the position of the strut mounts. This was more of an issue specific to me as my oil tank is in the way on the passenger side, and it's a tight fit on the driver side too with my cage down bars. On a different car that wouldn't have been an issue...
Old 08-01-2019, 06:29 PM
cpd004's Avatar
cpd004 cpd004 is offline
As far as I know they are stock and original to the car. I spent the better part of a weekend adjusting and readjusting the hinges never being able to get it to sit low enough in the back. The hood didn't follow the fenders too well either. The hood looks to be undamaged and in good shape. It very well may be warped, but doesn't show in an obvious way. It is extremely heavy.
Lightening up the front of the car would be great if it also solves the hood fitment issues.
Thank you guys for all of the feedback.
1971 Firebird
2017 SS
