Old 09-22-2019, 12:27 PM
dhutton dhutton is offline
Originally Posted by spacepirate View Post
Any chance you have part numbers to make it work on the block? I tried searching but get overwhelmed with all the different answers. I found the correct M12- 1.5 thread with 1/8th NPT but when I screw in the sensor it doesn't come all the way out the other side which I assume means it wouldn't get a good reading?
It will read fine. Certainly better than in the radiator. But if it is reading 250 in the radiator then simply moving it will not fix that. Something else is wrong imho.
You should get a code reader for the bus and see what the ECM is reading for temperature as suggested earlier.
Old 09-22-2019, 12:33 PM
spacepirate spacepirate is offline
The Nu Vintage sender is definitely what I have and it's shallow so when placed in the M12 -1.5 it never comes out the other side. Is that fine, or does it need to extend outward past the tip to read properly?
And the gauge has always read that high since I had it up and running.
Old 09-22-2019, 12:41 PM
It will work fine not sticking out.
Old 09-22-2019, 12:34 PM
Is your IR temperature meter reading Celsius? Probably a dumb question but....
Old 09-22-2019, 12:40 PM
Thanks for everyone's help. I think it's time to find a shop to take a look.
Old 09-22-2019, 12:42 PM
You gave up too easy. This is an opportunity for you to learn what you have...
Old 09-22-2019, 01:38 PM
You're right Don. I went ahead and install the sensor in the rear of the head, fill her back up and got all the air out of the system and she's maintaining 185ish!!
I'm gonna drive it around the block once the weather cools down a bit here and I'll keep you posted.
Am I crazy to think that maybe having the sensor right below the steam return would mean steam was going over the sensor and making it read that high?
Old 09-23-2019, 06:19 PM
randy randy is offline
Did you just start having this issue or is this the first start up and break in? Does the lower hose ever get hot?
Old 09-23-2019, 08:52 PM
It's been doing this since I got it up and running. I'm going to install the correct thermostat tomorrow and see if that helps, If not, I'm going to run some food coloring through the system and see if the water is actually circulating through the motor. I figure that will be a good indicator if the water pump might be bad. Just trying to eliminate all the possibilities one by one.
Old 09-24-2019, 03:13 PM
Ok so how many miles have you really driven it? Start the engine and make sure the bottom Hose gets hot. If it doesn’t the engine isn’t to operating temp or the thermostat hasn’t opened. The boring gauge will read that the engine is hot but until the thermostat opens up and the system bleeds you won’t get a accurate reading.
Again where do you live ?
