Old 12-16-2017, 11:36 AM
jimmythehand jimmythehand is offline
Mine is for a 68 but i think they should be the same. there should be a bottom bracket and some mounting hardware as well. here ia link to a pic showing the bottom bracket.
http://www.lsxmag.com/features/sema-...or-69-camaros/
the mounting hardware that came with mine included three bolts/nuts/and spacers. i could not figure out how to incorporate the spacers, so installed without just fine. I called C&R and discussed the spacers and did not come to a final conclusion, although they were very friendly and receptive.
Old 12-16-2017, 01:22 PM
bullittcustoms bullittcustoms is offline
That's exactly what I thought!! Thanks for the info!!!
Derek
Old 12-17-2017, 12:29 AM
I used the spacers to go inside the lower radiator support so it wouldn't crush when you tighten the bolts.
Old 12-19-2017, 10:27 AM
l2azorback l2azorback is offline
C&R now makes a heat exchanger for the Gen V LT4 application in a first gen with inlet and discharge on the driver's side (as opposed to the LSA application on passenger side). Same price too!
Regards,
Larry
Old 10-15-2019, 08:31 PM
randy randy is offline
Someone posted part number 56-00010 and someone else posted 56-00015. Which is it?
Old 10-16-2019, 03:18 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
LSA, LT4, or LT5? They make 3 different ones now. https://www.crracing.com/product-category/intercoolers
Instagram- camaroaj
Old 10-17-2019, 11:26 AM
rocketrod rocketrod is offline
56-00010 was discontinued and replaced by 56-00015.
I have a 56-00010. It's not engine specific. Mine is is made to fit in a 1st gen Camaro. It could be used in other vehicles but you may have fitment issues and it will require you to fab your own mounting brackets.
Rod
1969 Camaro - LS2/4L70E
Old 10-22-2019, 11:06 AM
is it worth it going to a 56-00015? The zl1 heat exchanger is much cheaper. I know the C&R piece is "bolt in" but at $750 is it worth it and how much more efficient over a stock unit?
