Old 11-06-2006, 11:50 PM
I feel you pain Lead, we have two dogs, and if something happen to them........ Good luck with the surgurey.
BTW, if you run 345s on 12" rims they are not wider then 335s on 13" rims. I have put Project Prodigys 345 / 20s under Kevins leaf spring mini tub car and have measured section widths. The backspacing is differetn for the IRS then kevins live axle, but if it were the correct backspace they would fit.
Look at the following links and specs, this shows in Pirelli's the the 335 and 345 the same width on different rims, and shows Michelin's to be only a 1/4" different,
What will be most critical will be pushing the tubs in as far as they can go. Ordering the wheels and tires first, then mocking them in place to measure for the rear to be sure it is exactly the right width
http://www.tirerack.com/tires/Spec.j...e1=yes&place=0
Frank Serafine
Old 11-07-2006, 06:01 AM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Thanks guy's...
I may have left the feeling they could do something for him but in fact we went in 3 and came out two. There was nothing they could promise and 5k was a low fig + the vet told us dogs this size generally have serious complications after operations like that so on the vet's reccomendation, it was the end.
('Went pretty well this morning with the kids tough...+ side...)
Now onto good news!
Frank, i noticed that on;
http://www.customwheelsdirect.com/ti...nd/Pirelli.php
where thay have 13.6" on an 11.5" rim. I just didn't want to take the chance of relying on specs not founded from the real world. This is great news!!!
I'm thinking to do custom tubs at this point anyway since the DSE is cool but keeps the stock outer which would prevent me from dropping the car as low as i want it, no? ('Cause the tire would hit the part of the tub curving into the top of itself) Custom tubs will permit me to put the tire closest to the 1/4.
So i guess a 12" rim would work. (?) If i could use the hangers for 1 season it would be great!
I also have the engine (LS1) to put in etc....So it figures (well for me) budget wise that this is gonna have to be built in stages, i really want to get the look tough so i can ride in style nxt summer!!!
I'll re-read your post to sink it in later, i only wanted to say thanks! (to both of you)
And yes, Tracy, i'm going thru so much trouble for those big skins....but hey, This is HOT RODDING!!!! And its what its all about!
Gotta get to work now....
'Later
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 11-07-2006, 10:23 AM
If you are eliminating the outers and doing drag style tubs, you will have plenty of clearance with the 345s on 12" rims. I WOULD NOT try a 11.5" rim, 12" is perfect.
Check out Prodigy again
http://prodigycustoms.com/mikes-prodigy.asp
Frank Serafine
Old 11-07-2006, 01:39 PM
Leadfoot1's Avatar
Thanks Frank,
I looked at the wheels pics and they look awesome. The reason i wanted to go to the the max size rim is because i didn't want tire Bulge. I'd prefer them to be kinda pulled under the rim (a la Ferrari etc). When i measure the inside lip of my tires they have 13" inside so i figured for them to stay that wide i'd need at least a 13" rim....Your 345's on a 12 inch look Very good! See....Real world data! Haaaa! Peace of mind....Now only to wait from Forgeline.
What is the BSpace on prodigy's rear wheels (only as a reference for looks as i'm thinking to put the most bs i can but am not quite sure...More is not always better than not enough or som'tin like that they say)
Tracy, sorry for hijacking a few spots! I saw your taking a break from typing today so i figure we should get pics soon????
Lead.
Edit!!
I just received anwser from Forgeline!
Mario, I checked the template and we are able to clear the brakes. I took the time to give you a run down of what we would be able to build and still fit around the brakes.
19x8.5 we can offer a 4.7 bs, 5.2 bs or a 5.7 bs.
The rear wheel we can only offer a 7.2 backspace due to the availability in rim shell sizes. I will check to see if there are any new offerings in the rim size that I may not be aware of. Are you doing IRS or solid axle rear end? Is the 7.2 going to be a problem if that is all I can offer. I know in the past, customers have just made the adjustment in the rear end length. We can go with more backspace on the rear, just not less (that I am aware of).
LEADFOOT1
Old 11-25-2006, 07:26 PM
Leadfoot1's Avatar
Tracy,
Would you have a pic of the lower arm of your Q-Link attached....My car is getting tubbed right now and i encountered a problem. I Hit the leaf at its front half even with its rear moved in (offset hangers) and it now seems i won't be able to run my leafs (or tires)....i have 14" of tire width, and 13" from outmost part of tire sidewall (measuring in) to the outmost part of the leaf)
Thats a killer as the brakes/ wheels/ brackets/ tubbing/ framing budget is getting thin. I didn't plan to put the suspension in right away (i just sold my LS1 today to make that happen now...Good deal tough, paid 600$ w/ 4L60 and sold for 3k :-)---good, but now Gonna have to run the old school 327 for the season)
Now i need to decide what to run for suspension in order to get some clearance;
I'm really interested in finding out how much clearance you get from the tire to the leaf vs tire to the rod that replaces the leaf (?) The Air Ride guys say i would only gain 1/2" with their systems bar size (care to measure the dia of yours?) It seems like its not much and might not even do the trick. I need the car to be done to eveluate this for sure but its the time thats killing me as Forgeline is running a sale 'till monday and i need to take decisions NOW! If the tires are not going to fit...I'm gonna have to get smaller ones and at that point i might change the whole set up. I'm going thru many toughts and ideas.
I really lean torward the Airbar and their lower arm is same concept as the Q-L, so i tought i would ask. I really love the Q-Link but the ride and ease of install of the bar are appealing to me...Not to mention the drop.
Any help appreciated!
Lead.
Hey, any progress on the car?
LEADFOOT1
Old 11-30-2006, 03:26 PM
tracy's Avatar
tracy tracy is offline
Default Rolled it outside today!!!!
Lots of progress since my last update. The car is officially a roller now..
You can see that I am already in trouble with the law!!
I love these Forgelines...Thanks GPSuperstore!!
Goodies Speed Shop
Old 11-30-2006, 03:36 PM
tracy's Avatar
Default More progress shots
Goodies Speed Shop
Old 11-30-2006, 03:37 PM
GHOSTDANCER GHOSTDANCER is offline
Thumbs up
Looks Killer
Old 11-30-2006, 03:45 PM
tracy's Avatar
Default A few more...
Firewall is prepped for the body shop...thats next..
Goodies Speed Shop
Old 11-30-2006, 03:52 PM
Rybar's Avatar
Rybar Rybar is offline
Looks sick Tracy, you are moving along nicely on this project!
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
