Old 05-07-2020, 03:29 AM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
And I finally got my brakes ordered. I was dead set on running 6 piston Baer brakes but unfortunately my wheel specs, spindle and clearance won't allow for it. Its a long story, but my only option was to either rehoop my front wheels (800 a piece) and use my ATS spindles and Baer Brakes. Or I can go with Wilwood using stock spindle. Even the Wilwood are going to require me to switch over to a taller Forgeline center cap in order to clear the hub dust cap. In short, the pad on my wheels were machined down to have a deeper offset, this killed the caliper and hub clearance..live and learn. Good news is I can still run 14" rotors with the Wilwood, so I am sure it will stop just fine lol.[/QUOTE]
What backspace did you end up ordering the wheels?
1967 Camaro RS
1969 Camaro coupe
Old 05-12-2020, 11:55 AM
lsuguy's Avatar
lsuguy lsuguy is offline
What backspace did you end up ordering the wheels?[/QUOTE]
18x9.5 with 6.5" of Backspacing, at Speedtech's direction
Old 06-05-2020, 05:09 AM
lsuguy's Avatar
Want to know what a bad day looks like..apparently when I moved last year this happened....
Old 06-05-2020, 09:08 AM
That sucks, sorry to see this.
Old 06-05-2020, 11:18 AM
dmc69's Avatar
dmc69 dmc69 is offline
Originally Posted by lsuguy View Post
I also purchased a steering column from GM Tilt. Since I plan to use push button start this is a shaved key column Have not installed yet but we all love pictures so here they are:
IMG_0073
IMG_0072
IMG_0074
I also purchased A DSE dash insert to begin the thoughts and overall layout for my dash panel. Not much progress here outside of the switch panel that you see a couple of photos of. I found a source for very high quality switches with a huge assortment of labels that illuminate. Overall a very OEM look. If anyone needs the information just let me know and I will pass along.
IMG_0078
IMG_0077
IMG_0076
IMG_0080
Where did you get the light switch panel? Very nice touch.
DMC69- 69 SS350-LS3/6speed
Old 06-05-2020, 02:38 PM
dhutton dhutton is offline
Those do look good.
Old 06-05-2020, 05:59 PM
lsuguy's Avatar
I still have it and do not plan to use. Shoot me a PM if interested.
Old 06-05-2020, 08:17 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by dhutton View Post
Those do look good.
https://rockerswitchpros.com
I've considered them myself. Yes, they are nice.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-06-2020, 09:42 AM
ScotI ScotI is offline
Just went to the site & poked round on the 'demo' model. Very nice!
Old 06-06-2020, 10:32 AM
I agree, cool ideas when you need a rocker switch versus the standard switches out there.
