Old 07-25-2020, 01:15 PM
ScotI ScotI is offline
Originally Posted by tdishon View Post
I wanted a tilt up bed floor to access the transmission(it's in the rear). Also, I need to remove the top shock mount to take the rear tires off. I might as well have the fuel fill under the bed(still undecided). But the battery will be under the tilt bed for sure. All in all, just for easy access to everything. It does make changing the tire cake.
I'm setting the floor up on my patina 64swb in a similar fashion (center wood between the tubs will be hinged). Easier access to the exhaust, batt, shock mounts, gas tank components, & differential if needed.
I know on mine, rear tire changes are still going to be a fuss....
Old 08-01-2020, 03:45 PM
tdishon tdishon is offline
Bed floor coming together.
The Following 2 Users Say Thank You to tdishon For This Useful Post:
camcojb (08-01-2020), Goosesdad (08-02-2020)
Old 08-01-2020, 05:31 PM
dhutton dhutton is offline
Looks great.
Old 08-22-2020, 07:36 PM
Tilt bed framing done and working. I have several rubber adjusters in several places that keep all squeeks away.
The Following 5 Users Say Thank You to tdishon For This Useful Post:
camcojb (08-22-2020), dhutton (08-22-2020), EVIL SS (08-23-2020), jarhead (08-22-2020), WILWAXU (08-23-2020)
Old 08-23-2020, 04:12 PM
Nice work on the bed! Will you keep it as a wood bed?
Old 08-23-2020, 08:59 PM
Yep. Working on the wood next. Mar-K has nice stainless strips that hide the hardware between the boards.
Old 08-24-2020, 07:52 AM
Do you mind confirming what your source was for the pivoting hinges?
