Old 12-18-2020, 05:24 PM
Beechy's Avatar
Beechy Beechy is offline
Default Dash Plug
John.....great vision as usual
It's hard to see from your side-on image but it seems you have three separate curves at the moment??? I would make the instrument mounting surface as one continuous curve (in top view).
Because each instrument has a flat mounting flange, and you main surface is curved.....this is a negative curve in your case, you have to raise or depress the surface locally around each shape. This will look much sweeter than having the main surface stopping and starting.
Attached is my Camaro instrument fascia which is one-piece vacuum formed ABS over a plywood/bondo male mold. You can see that each penetration has its own flat flange about 3/16" wide. The radii around the holes are much softer than you will be able to achieve in fiberglass, but I had to go that route for the vacuum form material to flow into the flat areas. Top left air outlet needed raising AND lowering the attaching flange because of the complex (compound) curve at the end of the dash.
BTW....that grill and surround are a commercial stainless steel sugar shaker like a donut store would have.....shhhh.....our secret
Also my main crash pad surface is a positive curve (with the center higher than the ends) ...... The central warning light area was then machined flat, the border trenched out, and the depressed flanges go deeper again. NEVER CREATE A FLAT SURFACE ON AN AUTO BODY because surrounding curves will make it look hollow.......also shrinkage around edges when the resin cures will pull your surface hollow. Even on a long wide panel that you want to look flat (like a fascia between tail lamps for example) should have 3/16" positive or negative curve in it......never use the plywood dead flat.
My instrument pad is loosey goosey compared to what yours can be ....cos mine is racecar and both left hand and right hand were done in TWO EIGHT HOUR DAYS! You will get better definition using gel coat and glass.
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 12-18-2020, 06:51 PM
Beechy's Avatar
Default Dash plug 2
There you go John.....alternative sections thru.
Upper section is obviously instruments square to the car....not ideal visually...also prolly get reflections on outer instruments.
Lower is the best.....faces parallel to base surface. More driver focused.
More options.....mount them deeper......tilt them halfway between the angles shown.
Note: these are NOT the images Marty was looking forward to
Jim Grant
(Dual citizen)
The Following 2 Users Say Thank You to Beechy For This Useful Post:
Goosesdad (04-03-2022), syborg tt (05-19-2021)
  #493
Old 12-18-2020, 07:28 PM
I think the dash layout if great.
I put the tach dead center above the steering column in my car. With the speedo moved down to beside the steering column arch, I could actually see the whole thing. The factory gauges were cut off at the top because of the steering wheel and how I sit in the car.
Old 12-19-2020, 10:29 AM
Goosesdad's Avatar
Thanks Trey and Jim.
Jim - wow - thanks for all that detail...appreciate all you say! I'll send some more pics this weekend. The insert is actually 3 planes, to do what you suggest as having the gauges in direct line of sight. And then the outer trim is curved.
And....doing that CAD, over and above sir!
Have a great day!
John
My Build Thread:
The Following 2 Users Say Thank You to Goosesdad For This Useful Post:
Beechy (12-19-2020), syborg tt (05-19-2021)
  #495
Old 12-21-2020, 08:28 PM
Goosesdad's Avatar
Didn't have huge progress this weekend but some...! Keeping the plug so there are reliefs for the mold and keeping proper gaps for the dash wrap material (leather or alcantara) along with the insert for the gauges....just time consuming.
Mock'd up some gauges (mdf painted black with color printed gauge faces) just to get the feel of the layout in 3D. This insert will likely be carbon. Not sure yet. Of course all of this wood is just mock up for the fiberglass mold. Lots more to come.
Started the front edge of the dash, will build it back to the gauge cluster next.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (12-28-2020)
  #496
Old 12-21-2020, 09:49 PM
Damn your practice gauges had me fooled, having them like that gives you a great sense of the final piece. Nice job.
The Following 2 Users Say Thank You to waynieZ For This Useful Post:
Goosesdad (12-28-2020), Spiffav8 (12-28-2020)
  #497
Old 12-21-2020, 09:50 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Very nice!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
  #498
Old 12-22-2020, 03:56 AM
Tinker's Avatar
Tinker Tinker is offline
John, it's a shame you are rushing this project.
Seriously though You have a car that has detail second to none. Be proud of yourself and thanks for sharing your talents!
Chris
Old 12-22-2020, 07:28 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Originally Posted by Goosesdad View Post
[B]Starting the plug for the fiberglass dash/center console. Have had this design in my head from the start, finally getting to see if it will work!
I realize that putting the all of gauges off to the side is a little unconventional
I for one, LOVE unconventional!!! Great idea keeping true to the basic shape but doing your own layout.
Jeff-
Old 12-28-2020, 12:26 PM
Goosesdad's Avatar
Originally Posted by 214Chevy View Post
Very nice!!
Jeff-
Thanks guys!! Trying to keep some of the factory lines..
Have a great day!
John
My Build Thread:
stan65 (12-31-2020)
