Old 07-19-2021, 04:51 PM
Build-It-Break-it's Avatar
Originally Posted by protour View Post
How does this mount to the firewall?
You drill a 2" hole in your firewall, 2 holes for the mounting screws. Mount the firewall pass through on the engine side around the harness, have a buddy tighten the the nuts on the inside of the car and your done.
Ahmad B
Old 07-20-2021, 04:28 AM
protour's Avatar
protour protour is offline
Ohh so its just the 2 bolts, no sandwich plate on the backside to keep help pull the firewall flat if its not on a perfectly flat spot. The thinner passthroughs have more bolts and conform to the firewall, my concern is the 2 bolts may not suck it perfectly tight to the firewall. That would be remedied with a 1/8" backing ring with the 2 bolts. I can easily fab that up. I'll consider picking one of these up. Thank you!
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 07-20-2021, 08:36 PM
I hope these images help
Ahmad B
The Following User Says Thank You to Build-It-Break-it For This Useful Post:
waynieZ (11-29-2021)
Old 07-20-2021, 08:39 PM
There's also an ebay seller that sells one for a smaller diameter harness(for Hondas) that I'm going to be using on my main vehicle harness. The item is listed under "k tuned firewall grommet" . I would post a link but I hate posting up links then they expire.
Ahmad B
Old 07-29-2021, 07:44 AM
syborg tt's Avatar
Got mine the other day and it will be mocked up this weekend and then off to get Anodized black.
marty-mj
Old 07-29-2021, 11:32 AM
jmac jmac is offline
These are very cool. I see on his website there's an option for hidden or visible fasteners, which one do you have there? I was looking on his site but see no way to contact him to ask. I'd like to see a version of both of I could.
Thanks!
My 1967 Camaro
Old 07-29-2021, 12:02 PM
syborg tt's Avatar
Thanks!
So the pictures I posted are the hidden hardware version as you have to tighten the nuts from inside the car.
And the version that Ahmad B posted is the version with the bolts inside the engine bay.
marty-mj
