Old 03-03-2019, 11:04 AM
Tony V Tony V is offline
I switched to a Ron Davis with in integrated Oil and P/S cooler and couldn't be happier....racing in 90+ temps never approaches "hot". Nice workmanship....
Old 09-24-2019, 09:30 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I've had a Ron Davis before and it was great. Wouldn't hesitate to use them again. It cooled very well and efficiently which says a lot due to the fact I live in Texas where the summer temps are the equivalent to hell. However, I just ordered an AutoRad last week because I wanted the cool Core support and ordered an intercooler too with the A/C condenser and love how the mount everything all together nicely. Anyone got any stories...good, bad or indifferent about their AutoRad.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-05-2019, 08:55 AM
pannetron's Avatar
pannetron pannetron is offline
The Griffin I installed in my '66 Chevelle w/ LSA started leaking from multiple places after just two years. Just installed an AFCO radiator to replace it. The fan shroud on the Griffin was a better design but the AFCO radiator is much more efficient at shedding heat.
Old 01-01-2020, 12:34 PM
cpd004's Avatar
cpd004 cpd004 is offline
My Griffin is leaking. This is the second one in 4 years with minimal driving. The first was replaced by Summit as a warranty claim. Now, I'm back to square one.
1971 Firebird
2017 SS
Old 10-05-2020, 09:20 PM
I'm in the same boat with Griffin, mine just started leaking at the upper corner where the tubes are bonded to the end tank. Hopefully Summit will help out, I have had it installed for just over 2 years.
Old 10-07-2020, 07:47 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
I went through three Griffin radiators in 4 years. I'll never buy another nor recommend one. I replaced it with a triple pass from Jegs. So far so good but time will tell.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 08-12-2021, 05:48 PM
Ttype455 Ttype455 is offline
Originally Posted by patriot68 View Post
Entropy radiators
I’ve done a lot of researching on radiators. That’s funny you mentioned entropy that you pointed out. I was planning on going with them also. I want USA made.
It seems a lot of companies like griffin are going overseas, and I’m reading “a lot ”of bad reviews on them. But I guess they used to be a lot better years ago. Seems quality has really gone down.
Old 08-13-2021, 04:18 PM
joeko23 joeko23 is offline
Entropy has a lifetime warranty. I got for my 69 LSA project. It’s made very well and the fans seem to be very powerful.
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
Old 10-01-2021, 11:22 AM
57vette 57vette is offline
Using a Cold Case in my 461 BBC 69 Camaro. The radiator brackets locate the radiator 5/8" further back than the stock radiator, seems to be the only complaint many users have had. I had my brackets cut off and re-welded same as factory radiators. Otherwise really nice quality and customer support. It has two tubes that are 1-1/4" which is pretty impressive.
Works fine but I suspect my fans could be more powerful.-Mike
Old 10-01-2021, 11:35 AM
partsguy57 partsguy57 is offline
Wizard cooling..
Sent from my SM-G965U using Tapatalk
